Williams and Hussey Moulder
Dave Winters
>I need to make a bunch of radiused top window casing. I have heard about the Williams and Hussey Moulders, and checked out their website.
But I still don't get how they work for radiuses mouldings. And it sure doesn't look like much machine for $2600.
However, I've priced the stuff made up from three vendors and they want between 20-30 dollars a foot!
Anybody have experience with these things?
The profile is a simple r2e (radius two edges).
Thanks!
Re: Williams and Hussey Moulder
Rick L
Re: Clone?
Rick L
>Shopfox makes a clone of the W&H for half the price.
Dave Arbuckle, Plano, TX
>The 206 Owner's Manual has instructions on how to make constant radius moldings. It starts on page 29 of the PDF.
For elliptical moldings, there's an add-on part covered in its own manual.
Hope those help. I don't have a W&H, but I've admired them from afar for a long time. :-)
Keith Newton
>I would like to have one also, but for two radiused edges, why not just use a router.
I think on the W&H you affix the wood to a template underneath, that rides between guide pins as it feeds it through the cutter.
Kirk D.
>Could you just use a round over bit in a router to radius the edge. Results will be just fine with a major savings.
I have one
Rob Sandow
>I've never used it to make radiused mouldings, but they sell an attachment that does the job for any arbitrary radius. For a fixed radius, all you need to do is make a simple guide out of a couple pieces of plywood set with the correct radius and you can run them through. This is truly a magnificent machine. It makes super smooth cuts up to 3/4" deep in one pass with only 2 cutters. I was amazed the first time I used mine.
If you are patient and look around, you can get them on the used market for $1000 or so. That's what I paid for mine about 5 years ago.
Rob
Wess in NJ
>I have a W&H moulder and have made lots of radius and elliptical casings with it. It is a great machine. However, if your casing is really just flat stock with a radius on both sides, the moulder won't really help you. Make your blank and run a router along both sides, that's how I would go about it even with the moulder in the shop.
