Bandsaw circle cutting jig
Rick Snyder
>Built a bandsaw circle cutting jig. I have a 1/2 inch blade on the bandsaw and started to make the cut and the blade started to bind up. whats the problem? When I have seen this done (on TV), the blade they use appears to be larger than a 1/4 inch, or is that the right size. I have put in several different setting on this jig.
Thanks Rick
