Where hardwood lumber comes from 3A-big logs
Bill Tindal, E.TN
>Part 3A-The Log Yard Revisited
I know we already covered the log yard, but it is such a �cool� place (unless you are splitting log end trimming for firewood and it's 90 degrees). That is my blue trailer in the back ground of PIC 3 ready to be loaded with end trimmings. But I digress again.....
Later in the week I will do an installment directed to people that own timber who may sell it some day. I see many economically unsound decisions made when selling timber and this post will illustrate this point.
The format in this installment is different because there are more pictures. In the main post (what you are now reading) I will put the text and the pictures will follow below.
Logs typically come into the yard with trucks like what is shown in PIC 1. These are boom trucks and they have the advantage that the logger can load the truck by himself with the mounted crane. In fact, with the availability of these trucks it is common now for the logger to work alone, building roads, felling, skidding, loading and hauling to the log yard. This truck was unloading 3200 bd ft of very nice 16� poplar logs. The logger is up there sitting in the chair of the boom because he had to climb up there and get the boom out of the way of the unloading crane.
Once on the ground the logs are spread out for inspection and grading (PIC 2). The length of the logs is measured with a neat tape fastened to the graders belt, the log grade is determined from the diameter of the log and what ever defects are showing (crook, knots & rot) , the log is scaled (scaling is the term for measuring the bd ft in the log) and this information along with species is recorded on the end of the log with crayon.
These crayon marks are shown on the end of the log in PIC3. While we can�t make out what the marks mean, the log yard people can. Next, someone comes along with a bar tag and portable computer and enters the bar code and log information into a data base for inventory and payment of the logger. The rule shown is used to determine the bd ft in the log. It is scaled just like the lumber rule described in Part 9. There are scales for the various lengths of logs stamped on the ruler. The ruler is placed at the diameter of the log and the bdft is read from the value on the rule that lines up with the interface between wood and bark. Hardwood is typically scaled with the Doyle Scale. The formula for the Doyle scale is
bdft = (D-4) squared x L/16.
In words, subtract 4 from the log diameter (inside bark), square this result and multiply by the log length in feet divided by 16. The Doyle scale substantially underestimates the yield from small logs. We will have a lot to say about this issue when I talk about selling your timber in the next installment.
Finally, the logs are loaded on a tractor trailer for hauling to the saw mill(PIC4). The haul from this log yard to the mill is 75 miles. Between 3,000 to 6,000 feet of logs can be hauled depending on the size of the logs.
Re: Where hardwood lumber comes from 3A-big logs
PIC 2
Bill Tindal, E.TN
PIC 3
Bill Tindal, E.TN
PIC 4
Bill Tindal, E.TN
Don O.
>Good stuff Bill, very interesting. Looking forward to more.
