How to cut Pyramid on tablesaw?
K.S.SONG
>Hi
I would like to cut wood block to Pyramid on tablesaw.
Size : base approx. 2inch length, 52 angle degree (1 1/2inch height).
I think it should be little bit difficult and might be dangerous work when cut third and final face after first & second cut.
So I looking for more safe and easier cutting way, especially using some useful jigs.
Are there any useful jig drawings or comments or site for this Pyramid work?
Should be very appriciated for your comments.
Thanks in advance.
K.S.SONG / SEOUL KOREA
Re: How to cut Pyramid on tablesaw?
John McGaw
>If it is permitted to have a screw hole in the bottom of the pyramid then simply screwing it tightly to the center of a 2" wide strip of 1/2" plywood a couple of feet long should work. Simply make the cut as a rip at the proper angle with the fence adjusted to the proper distance to avoid cutting into the strip. Rotate the block 90-degrees and cut again. Repeat four times and you should have your pyramid. It might be necessary to glue some 120-grit abrasive to the plywood to ensure that the block has no chance of shifting when the screw is tightened down. Avoid hitting the abrasive with the saw blade to keep from dulling it unnecessarily.
A similar jig could certainly be rigged from wider plywood with runners underneath to ride in the saw's table slots. I'd probably used one fastened to my sliding table but not everyone has one on their saw.
JKJ in East TN
>bottom of the pyramid then...
An old woodturner's trick is to use double-sided tape instead of screws. This method can hold large blocks of wood securely on a spinning metal faceplate so it should work well to hold a block to a jig for sawing. Woodcraft sells an excellent tape for this but for this application I suspect nearly any two-sided tape would work.
mbatarga
>Just use stock that is 2" square, sufficient in length to be safe. Cut the pyramid top using your miter jig. After you've cut the 4 sides, set the miter square to 90 degrees and just cut off the pyramid top off the length of stock.
John McGaw
>Yes, I know about two-sided tape but it might be more trouble that it is worth this time since the cube will need to be detached and re-attached several times as it is cut, thus the screw which can be loosened and re-tightened.
This is one of those problems that presents new answers every time you look at it. You mentioned "turning" and I immediately thought "vacuum chucking". If one had a vacuum pump arrangement a relatively simple vacuum clamping pad on a plywood bed would probably do an excellent job of this work.
>Do you want an Egyption Piramid or a tetrahedron?
An Egyption Piramid has a square base and four trianglular sides. A tetrahedron has four triangular sides.
I would thing the idea of setting the niter gauge to 52 degrees and cutting four sides of a 2 inch square sitck and tned cutting off the top would be the safest way to make a piramid. Not sure hwo I woudl do a tetrahedron.
PS, Did you ever make the spheres you asked about?
s.mackay@worldnet.att.net
>Mostly I do the faceted turrets for armored vehicals. My first couple I tried what your suggesting on both table saw and band saw. Yes, it got to be to darned close to the fingers and did'nt come out as precise as I wanted. I STILL wound up sanding each face untill it looked " correct ". Now a days I build my block " blank " and take each plane down with the belt sander. This allows me to take material off and check the piece as I go. I can always take mor off BUT I can't put it back on ! While useing the belt sander I'm also left with a flat plane. Just my wierd way of doing things.
Ted Wong
>Not sure what your skill level is. But in the school shop I teach at we have students come in every couple of years trying to do multi-faceted shapes out of wood blocks. It can be done but I direct most students to the bandsaw and sander for cleanup. I feel it's much to dangerous to do these funcky shapes on the tablesaw.
Re: sample and cutting drawing
K.S.SONG
>Thanks for all.
I found exact Pyramid sample on www.precisionpyramids.com as upper photo.
Clean base without any hole/groove is preferable, but good idea for it do not come to mind yet.
As a next best, make a groove on base of hexahedron by drilling as fixing point with insert on mitre gauge like cutting drawing sky-viewed.
Insert may be smaller diameter & longer length like 2mm dia x 10mm length with steel.
Below cutting idea is still under considering and will hear more your comments.
Thanks.
K.S.SONG
JKJ in East TN
>>...the cube will need to be detached and re-attached several times as it is cut..
I think it could be done with one re-attachment. Attach the block to a longer board, cut one side, turn it around and cut the opposite side, remove, rotate 90-deg and re-attach, saw other two faces. An angled fixture would be appropriate.
In fact, this might be further simplified (and yield a number of pyramids) by first cutting two opposite slopes on a long piece of stock, attach that stock sideways to a wide base (plywood?) with 2-sided tape, then rip/angle the other two sides, cutting through the base.
However, I agree with the comment about using the bandsaw instead of the table saw. It would be much safer.
This is how I would do it
Charles Sharp
Henry (Raleigh NC)
>If you need a clean base with no screw hole, you can combine the approaches mentioned above; use both a screw and double faced tape. Affix the pyramid blank to a small scrap base with double sided tape. Then use a screw through a much larger jig/fixture into this small scrap base.
- I'd certainly want to ensure no unwanted rotation about the pivot point with a second screw, or with abrasive.
- I am not sure what depth of cut I can get with a 10" TS, but this would be my choice, for precision and cleanest cut reasons. This same idea would work on a Bandsaw or miter saw.
1. Mount the pyramid blank on a small scrap base, as described above
2. Select a jig/fixture base of at least 12" x 18"; big enough to safely run along the fence or mount a runner for miter slots
3. Mount the small scrap base to the jig base with a pivot screw and abrasive or a second screw
4. angle the blade to the desired 52 degrees
5. Cut and rotate
If I knew how to enclose a drawing, I try to confuse you further with that (smiley).
Henry
Re: Thanks for comments.
K.S.SONG
>I will try to cut it by combining with your helpful comments.
Thanks.
Safe work!
K.S.SONG /SEOUL KOREA
