Different kind of ramrod
Randy Johnson Connersville, IN
>Yesterday evening I went out to visit friends who are having an over the log muzzleloading match today.
The main purpose was to deliver a bowl to one of them and so the talk moved toward woodworking. That�s when I got to see a really nice ramrod.
Now, usually there isn�t much to a ramrod. They are either straight grain hickory or, if most of the loading is done at a bench, soft steel. Sometimes a wood rod will be decorated by having a dark spiral, �candy stripe� from one end to the other. Most of the people I know turn the rod over the flame from a propane torch to get the stripe. Supposedly it can be done with a string dipped in stain but I never had any luck trying it that way. The method used for the one I saw last night succeeded in turning a simple ramrod into an item of craftsmanship.
The dark line on this rod was made by having a dark wood, probably walnut form the spiral. The diameter was probably around 3/8 to give you some idea of how narrow the dark line had to be. He explained the method but I�m afraid he lost me pretty early. There is a lot of ripping and gluing involved and although the finished result looks like it was inlaid it really is not. I did understand that the layout starts out square in cross-section before being taken to the final shape.
In almost forty years of playing around with muzzleloaders I�d never seen anything like it.
