food safe wood finish
Anita DiMauro
>I have just cleaned some old monkeypod bowls and plates with the Formby's cleaning lotions and now want to be sure that the final coating is food safe. What do you suggest. Formbys doesn't have an FDA approved finish. PURE tung oil was mentioned as a food safe finish.
Thanks for your suggestions.
Re: food safe wood finish
Howard Norman-Prescott, AZ
>I have always used mineral oil myself.
Howard
Larry Clinton At Frankfort (Central)., Indiana
>Per all the information I have read on the web, no finish used today is not "food safe" after curing. All the current finishes are formulated without the lead, & heavy metals used in the past. However if you want to be absolutely certain, Walnut oil is a drying oil which will provide some protection. It is available at most health food stores - used for cooking and salad dressings as I recall. I have some in my shop - I did use beeswax, mineral oil and paraffin on cutting boards (applied hot) - bought some walnut oil to see how it would finish, but haven't used it yet.
John Veerkamp
>Mike Mahoney makes a Walnut oil that has been heat treated so that it dries faster than the walnut oil bought at the supermarket. It is available from Craft Supplies.
John
Non-Toxic
Howard Acheson
No strictly true. Since the mid 1970's all residencial finishes are required to be non-toxic when fully cured. As far as I know, the FDA has never designated any finish as "food safe".
That said, I don't know what the items are that you want to finish nor do you say what might be put into them. Most film finishes have the risk of flaking or otherwise deteriorating. While the flakes are non-toxic, they may not be "good eats". The treatment used on cutting boards and chopping blocks is mineral spirits with some paraffin melted in. The treatment needs to be periodically renewed and is no good for real hot stuff but it does offer a little protection.
Anita DiMauro
>Thanks to all who responded to my question. FYI, I am putting nuts, chips and dip into the bowls.
I presume that the walnut and mineral oil will not be sticky once it dries.
>Mineral oil is a non-drying oil. It will always have a cool, slippery feel to it, as it resides in the surface cells of the wood itself. Walnut oil is an oil that resides in the wood and to some extent in a thin film on top of the wood. It leaves a dull, close-to-the wood look and feel.
If you want more protection and a shinier surface, you need to move up to a wiping varnish. Many companies make these, and they go by names like "tung oil varnish" and wipe-on finish. General Finishes makes a couple (Seal-a-cel is a good one), Waterlox makes one called "Original Sealer & Finish," Behlen makes one called "Salad Bowl Finish" (or is it "Bar Top Finish"), and Swing Paints makes a couple god ones. I really like their "Antique Paste Varnish" for salad bowls. It goes on really thick and shiny, although it is not as easy to handle as a thin varnish. But it leaves a very durable film with a medium high sheen that reflects the curves of your bowls nicely.
Any of the above will work, so try one out and see how you like it.
Ellis Walentine, Host
where do you get the Swing finishes?
Bill Tindal, E.TN
john l. blue
>I used canola oil on this fish board I made to skin fish.
FDA approved finishes
Michael Dresdner
>Several companies make food safe finishes that are FDA approved. H. Behlen's Salad Bowl Finish, which Ellis mentioned, is one of them. It means they took the time and money to prove to the FDA that their finish is food contact safe. That does not mean other finishes are not -- only that most companies won't spend the money to get the FDA nod.
Other companies, such as Kerf's Wood Cream, make finishes using only edible components, which makes them FDA approved by default. (If each of the separate ingredients is food grade, and there is no known reaction between them, the resulting mixture is food grade.)
Shellac, of course, is also edible, and the vast majority of it in the US is food grade and used for coating candy and fruit. The difference between food grade and non-food grade? The non-food grade can be stretched and manipulated by hand, while the food grade is laid out via stainless steel rollers. Needless to say, virtually all shellac is now made by roller as it is much faster and cheaper, so even the shellac sold to woodworkers could probably pass FDA tests.
Interestingly, the one thing that made shellac, whose resin is edible, into something less than savory was the addition of methanol as one of the solvents. Zinsser, the only major shellac supplier to the wood industry in the US, removed all the methanol from their mixtures because it was mandated by Canada, and it was cheaper to simply make all their shellac able to pass Canada's restrictions.
Jorge Castaneda
>I finish my bowls and platters with one of the drying oils, walnut, hazelnut or sunflower, I buy them in the health food store.
They need to be applied several times in a row, apply, let it set 20 minutes, wipe out excess, let it dry overnight, repeat until the wood stops drinking. After that an occasional aplication of same will maintain the bowls.
Jorge
