OT: salvaging ceramic floor tile
pecker
>I had to remove about 100 floor tiles, 9" square from an entryway for repair to the floor.
I have about 60 new ones saved from the original installation, so I'll have to clean up about 40 of the removed ones. I'd like to get as much of the thinset mortar off the bottoms as I can in a reasonable amount of time.
Any ideas how to do this? I tried soaking one in some water, then scraped at it with a wire brush and a flat screwdriver. This sorta works, but was very tedious. So if anybody knows a better way I'd appreciate it.
Re: OT: salvaging ceramic floor tile
Thad Parker
>wire brush/wheel mounted to a rotary tool should be less work. My FIL has a wire wheel on his bench grinder with the gaurd removed...that would be a nice setup as long as you were careful of finger placement.
>If you have an angle grinder, use a heavy abrasive disk for metal or one of the tungsten carbide disks for wood carving.
Clint
woody r
>I have ground the thinset off several hundred tiles with a 4 1/2"angle grinder. My fixture is a flat surface with two stops slightly thinner than the tile placed in a "v". I nest the tiles in the "v". I operate the wheel with the flat about 15 degrees to the tile. I engage the wheel to the tile so that the rotational force holds the tile down and against the stops. If I were doing 9" tiles the flat surface would have a large thru hole so that air from the grinder could not build up and raise the tile. With my small tile I start and stop the grinder directly over the tile.
Right
Keith Newton
woody r
>Oooops... my previous post should have included "with a masonry wheel in a 4 1/2 inch grinder".
pecker
>Thanks. The wire wheel in a hand held drill is working nicely. I've been able to do about 6 or 7 per hour this way. Although the wheel is about half it's original diameter now.
