Major kitchen cabinet install gap problem? (w/pics
David Eisan
>Hello everyone,
I made the mistake of installing all my cabinets level and true in a kitchen that is anything but.
The old cabinets were pushed flush with the ceiling and had quarter round between them and the ceiling. Things rolled around in the old cabinets.
I now have the dilemma of how to fix this random gap between the tops of my cabinets and the ceiling. In some places the cabinets touch the ceiling and in other places there is a 3/4" gap. The face frame exposure above the doors is about 7/8".
Hindsight tells me I should have figured out the difference in level in the ceiling and made the face frames and side panels large enough to allow for scribing.
Any ideas how to fill the gap? Somehow I don't think caulk and paint is the answer. Neither is fixing the ceiling an option.
I am trying to think of some sort of trim design/style that I can put up there to fix things that won't look all stupid being made of various widths. I was thinking of making some sort of trim starting with a min height of 1/2" where the cabinets are flush, expanding to 1-1/4" at the worst gap. Add to this the fact that I deliberately made the face frame sides proud of the side panels, and that issue needs to be dealt with (mitre, mitre, mitre, another mitre, mitre, mitre, another mitre....).
I am thinking 1/2" trim with maybe a 3/8" quarter round with bead on both sides to mimic the doors. In order to do this with speed. I would prepaint the trim, scribe it and hang it with 23g pins
To make matters worse, time is seriously of the essence. I take possession of my new house in a little over three weeks and I really need to get this done ASAP!
Finishing the kitchen is one of the many jobs that needed to be done last month :(.
HELP!
David
Re: Major kitchen cabinet install gap problem? (w/pics
waroland
>I would remove the soffit and repair the ceiling.
Ed Snow
>Make some templates and create some fillers, then bondo and repaint. Or fillers then cover the seam with a bead. Neither are the best solution but I would opt for #2 if I were in your shoes.
Ought not to be that big a deal, I just had to do something similar for a restaurant I am trimming.
Paul Waddle
>I would go with some sort of trim to cover the gaps. pw
Mark Nowicki
>Actually, IMO, caulk, paint and a monochrome color scheme is the answer. We do it all the time trimming out windows which have to be installed level, square and plumb in houses that are anything but.
Mark
You really caulk 3/4" gaps?
John in New Mexico
>Never tried it that big, just assumed it would take lots of applications to deal with shrinkage and went on to other means.
As to the solution, I'd echo Ed's advice, though a bit tedious its a sure thing to look good and probably wouldn't take more than a day. You (David) could also try something like a mini baseboard with a small profile on the edge of a flat trim, just a little ogee or bead, no bigger than 1/4" or so. The flat part of the trim could then be scribed to fit against the soffit.
John
Nelson
>Ditto on removing the soffit.
Lee Gordon
Lee Gordon
>I would be tempted to trim the joint where the tops of the cabinets meet the soffit with cove molding (sort of like miniature crown molding).
>This is a standard issue when installing kitchen cabinets. The ceiling is never a flat plane perpendicular to the wall, regardless of how well the house was built. So all kitchen cabinets that go to the ceiling are either made to scribe to the ceiling or have some sort of molding there. Or they have a wierd looking gap at the top. I would cut a piece of wood 1/4" thick and wide enough to cover the widest gap plus 1/2" of the cabinets then put a 1/8" roundover on one edge. Paint to match the cabinets. Then install by scribing this piece to the ceiling and pinning to the cabinets, overlapping the top of the cabinet 1/2". I would take a chisel and notch the edge of the face frame where it extends past the cabinet side because mitering this molding around it would not look right.
Re: You really caulk 3/4" gaps?
Kneale Brownson in Northern MI
>Sure, fill the space to near the surface with backer rod, which comes in sizes large enough and small enough for this application, and then caulk over it. Easy paint fix.
>It probably doesn't matter, but I am lost in the time sequence. You metion the old cabinets where things rolled aroudn and that these are level. You mention taking possession of a new house, but these are new cabinets in your old house? Did you build new cabinets in your old house and then sell it?
Anyway, I agree with Moses. (And yes, you knew there was a problem, so you should have built in a scribe strip.) I would make a trim strip as Moses suggested, about 1 1/4" wide with a round edge. I woudl make it the same thickness as the face frame "projects" past the end of the cabinet (or a little thicker) and trim it or taper it to fit. As he suggested, notch or cut away the projection of the cabinet and let the trim strip past right through it. Caulk and paint.
Take a lesson from this. It the PPPPP thing. (Prior Planning Prevents Poor Performance). It would have been fairly easy to add a new bottom to the boxing or soffit above the cabinets. And it would not have cost a lot of money. Another thought would have been to shorten the doors and leave the space above them a little wider so the taper would not be as noticeable. Lots of possibilities come to mind, but I'm sure you have thought of most of them.
Matt Robinette, Mt Juliet Tn
>I would use 3/4" white cove molding and be done. White on white and it will not show. Caulk up to 1/4" gaps between ceiling and trim. Make sure you stuff backer rod ( it's gray foam you can buy at the BORG) in the cracks before caulk. Also paint the under soffit white to blend in. If that fails only invite intoverts over they would never look up at it anyway.
Matt
Perhaps I'll try it sometime...
John in New Mexico
>I've always assumed that much over 3/8" would be really hard to keep tidy. Backer rod also works great for keeping panels centered in a frame, so I usually have some around (not sure I've ever used it for its intended purpose though!).
John
Phil Thien
>I posted this in another forum, too. But just in case you don't see that, I would design a small shelf that runs the length of your cabinets and hangs down from the soffit. The purpose of the shelf: (1) Display a need collection of kitchen gadgets or license plates, etc. (2) Hide the gap.
Wallpaper border
Ed Mulligan, Cape Cod
Marv
>Hi David,
Ok, here's the solution....cut some tapered pieces of wood for the end gaps and strips of wood for the straight gaps, then caulk over those pieces or use joint compound and paint over the sanded surfaces.....it will be quick and gorgeous, trust me.....Marv
Re: Perhaps I'll try it sometime...
Mark Nowicki
>I use "caulk and paint" as a generic expression. Probably "muck it up" is clearer. I agree with you, 3/4" is too much to caulk without some filler or backer.
Mark
