Block Plane Selection and Rehabilitation
Bob Smalser, Seabeck, WA
>I gave my heirloom Stanley #60 � away to the oldest boy awhile back thinking my larger Stanley #65 alone would suffice, and miss not having a small plane for the apron pocket.
So for 60 bucks at auction I bought some antique tool dealer�s collection of rejects� either lesser planes, stubby irons or missing parts. At the top are a crude Stanley #110 on the left and Sargent�s idea of a low-angle block on the right�an adjustable mouth, but too large for my hand and too little support for the iron. At the bottom from left to right are two, more desirable Stanley #60 1/2 low-angle blocks, a Stanley #65 also with a low-angle, 12-degree bed, and a standard-angle Stanley # 9 � with a 20-degree bed�all with adjustable mouths. I�ll rehab them all and sell or give away what I don�t need. I order the parts required from Stanley�eccentric levers ($2.00), a replacement iron ($6.00) and miscellaneous screws from their catalog:
http://www.stanleytools.com/?TYPE=STATICLEFT&PAGE=partsservice.htm&LEFT=left_partsservice.htm
I dismantle them and toss them into a phosphoric acid solution overnight. The acid attacks the rust without touching iron or steel, and leaves behind a protective coating of iron phosphate in pits and recesses, inhibiting further rust. I much prefer this rust removal method to any other for tools used in damp boat sheds.
A day later all rust has been converted to crud that has to be cleaned off.
I begin with a coarse wire wheel, followed by a bath in hot soapy water with a small wire brush to clean the recesses, a good rinse, and drying over mild heat:
The after-rust where I scrubbed off all the iron phosphate is removed back on the buffer-grinder using a fine wire wheel�
�with special cleaning attention with a Dremel Tool given to the critical bed and mouth areas.
I buff the exterior surfaces to a shine using green rouge.
Continued�..
