Veneer over same species
Floyd
>I am building some walnut raised panel doors. I would like to put some burl veneer (or other figured walnut) on to a walnut substrate so that when I raise the panels the panels will have some interesting character. I know the walnut substrate will move but I would assume the veneer, being the same species, will move the same amount and not crack. Or, am I making a bad assumption. Will the glue move at a different rate and cause problems?
A professional cabitnet make said this is done often and that it should work fine.
Any advice would be appreciated.
