Frams and Panel Doors
Ed Cessna
>I �m in the process of making two frame and panel doors out of cherry. To get matching panels, I resawed them from one piece of wood. The resulting panels look gorgeous. However, there is one problem. One of the panels has two cracks, one 2� and the other 2 1/2.� The cracks are completely through the �� panel and about a sheet of paper wide. Can I fill the cracks and save the panel? If so, what do I use as filler?
Thanks for the help.
Ed
Re: Frams and Panel Doors
Larry Clinton At Frankfort (Central)., Indiana
>Ed - I would first see if you can "close" the cracks with clamps. If so, I would use a hypo with needle to force glue into the cracks and clamp them closed. I have just had a couple of white oak panels crack slightly and glued them up before I finished milling them - the crack is no longer detectable. Otherwise I would use liquid hide glue - apply to the crack as above and fill with sanding dust from the panels. I would then sand while the glue is still wet to finish filling. This should make the cracks disappear.
