Remote controll for dust collector
jared
>remove xx for email
Since I didnt have a lot else to do this morning, I was looking at the woodcraft website. I see that they have remote controls to turn on your dust collector marked down. It had a key chain type switch to turn it off and on. I could not determine the brand of the unit from the description but the price was just over $50 for the 220 volt unit. Do these things work ok and are they worth the trouble? I dont have a real big shop but often find myself starting a machine without walking over to turn on the dust collector just because of accumulated clutter on the floor and too many projects in process. And no, just cleaning up the shop isnt the answer. Jared
Re: Remote controll for dust collector
Don Evans
>I purchased one of those about a year ago when my x10 stopped working. It works, what more can one say really. I'd hate to walk back and forth to operate a switch every time I wanted it on or off.
Don
Jesse in New Mexico
>I love mine. I put it on a chain and wear it around my neck in the shop. Makes it easy to start the dc (and if it isn't easy, I probably wouldn't do it). Its very reliable.
I bought mine from Oneida, paid more than $50. No experience with it, but I seem to remember someone posting that you can get them at Radio Shack. You might search the archives...
you will like it
robert davis
Dave Bair, Eaton Rapids, MI
>Just make sure you can buy a replacement remote (a price for the remote alone will be listed). Fixing them, or replacing the entire unit, is more expensive than just replacing the remote.
>I bought one of the remotes from Penn state industries about 6 years ago. I absolutely love it. I've dropped it a bajillion times and I don't think I've changed the battery but once. If it died I would have to buy another, I don't think I could survive without it.
Rob Stokes in North Vancouver
>I picked up one a while back and my wife couldn't understand it as my DC is about a 7' walk from my TS :).
But I'm amazed at how much more I actually use my DC, particularly when I'm doing those little one-off cuts on the TS. I hang the remote off my apron strap where it's easy to get to.
Always glad I spent the $$
Rob
>I put the Long Ranger Blast Gates on my system that have the micro switches on them. Open the gate and the system comes on. I really like them. Makes turning the system on and opening the gate a one step process. I spent a lot of time arranging my gates to be convenient tot he switch for the machine.
Whatever you do, make it easy to use the DC. You will use it more and like it better.
Nelson
>I also have the Long Ranger blast gates from Woodcraft, they work great. Had a remote control before but prefer this system over a remote.
A Different Solution
Mark McC
>Instead of a remote for my 11"x24" basement shop I simply wired a switch for the outlet my DC is plugged into and located that switch right in the middle of the shop beside the TS, which is adjacent to the jointer,and the planer ..you get the drift.
I have to try hard to take more then 2 or 3 steps to turn the DC on or off. Guessing maybe $15?
Pat Evans
>Short of an elaborate (i.e. expensive) system, the remote controls are great. Mine came with 2 remotes, one of which stays clipped to a belt loop while I'm in the shop. I prefer it to gates that turn the DC on. I frequently turn the DC on and leave it running while I go thru several operations... jointer, TS, planer, etc. I wouldn't want to be starting and stopping the DC each time. I would eventually like gates that open and close automatically when I use a machine.
Still another solution
Gene Gauss
>I installed a number of switches in my shop, all wired in parallel, and one located next to each blast gate and wired so that closing any switch activates a relay that turns my DC on.
remote here Re: Remote controll for dust collector
del schisler
>http://www.highlandwoodworking.com/index.asp?PageAction=PRODSEARCH&txtSearch=dust+colector+remote+control&Page=1
I have this one and it work's very good del
Anyone have a 20amp 120V version?
Ells in Boulder
Re: Anyone have a 20amp 120V version?
Glenn Madsen near San Francisco
>Rockler sold a switch for use in building a router table. Big buttons, like on the Unisaw mag switch, although this one wasn't a mag switch. Just a switched extension cord, with big, convenient buttons. Plugged in my (slightly-modified) Delta DC, and it works pretty well. The switch is mounted on the shelf unit to the left of the table saw, right of the lathe.
Works pretty well for $15, and gets the DC back into the corner hiding behind the wood rack.
My preferred solution
Larry Marker
>I mounted inexpensive microswitches (from Radio Shack) on each blastgate. They are all wired in parallel and activate a relay to turn on the CD. Opening any blast gate automatically turns on the DC. Not only is this convenient, it keeps me from forgetting to close the blastgate when I'm through.
Larry
Radio Shack Remote
Tom MacGregor
>I posted about the Radio Shack remote a while back - It's marketed for remote control of a single outdoor outlet and is rated for 13A at 120V. My dust collector is a 55gal.barrel-top mounted impeller with an aftermarket 5 micron side bag powered by a Leeson 1hp motor rated at 12A wired for 120V. It cost about $25 for the remote and I've had no problems with it at all. Check the plate on your motor and make sure it really needs 20A to run. Or even better, you could use a clamp-on amp meter to find what amperage your motor actually draws under load. It might turn out to be low enough to use the cheap remote.
Bob Fawcett
>I built my own.
I used an extension cord, 2 aluminum outdoor style boxes, and a heavy duty switch and outlet. Mine is 120V 20A DC.
I cut the plug off the extension about 2 feet from the end of cord. I wired this into one of the boxes and connected to the outlet. I wired the rest of the cord into this same box and connected it to the outlet. The other end has the other box and the switch attached. The outlet is connected so one side is hot all the time and other is switched by the switch. The box with the switch has 2 small magnets glued to it so it sticks to any steel surface.
Plug in the plug, plug the DC into the switched outlet, take the switch box to whatever tool I am using. I have about 20' reach. The DC is one of those on wheels and not permanently connected to anything.
