A55 Smoothing Plane
Gluing - Conventional wisdom
nixonp
>I know this sounds stupid but when gluing two surfaces together, for instance two sheets of plywood, is it highly recommended to apply glue to both surfaces, or will a good coat to one surface only be essentially as good? Pardon the question.. but I was wondering what the conventional wisdom is here...? I'm almost certain that after you finish laughing you will advise to coat both surfaces but wanted to hear what the experienced people are doing.... for instance a table top made from two pieces of 3/4" birch plywood....?
Re: Gluing - Conventional wisdom
Both surfaces.
Virgil johnson
I was taught!
Lee Schierer - McKean, PA
>Glue doesn't need priming, so applying ample glue to one surface should be sufficient for a high quality bond. Depending upon the surface area, taking the time to coat both surfaces could result in the glue on the first coated surface drying before you get it spread on the second. When in doubt spread the glue a little heavy and deal with the squeeze out. Only contact cement needs to be applied to both surfaces.
Lee
I coat one surface, but
Bill Tindal, E.TN
>Presuming we are talking about aliphatic resin glue (Titebond for example)......What is required is that both surfaces be wet with adhesive. If you put enough on one surface enough will transfer to wet the other. Put too much on and squeeze out will be messy. There is so much surface area in face gluing that failure is unlikely. In your application I might use contact adhesive and in that case I coat both surfaces for insurance.
Beginners probably have better luck coating both surfaces; I certainly did. But in a furniture factory only one surface is coated during edge gluing for example, but the coating is done with a precalculated reproducible amount of glue, so the result is just the right amount to wet both surfaces.
Fred West in West Chester, PA
>I was taught and continue to do so to this day to apply the glue to one side but slide the two pieces together to spread the glue. You will very quickly feel the tackiness kicking in and it give you a tremendous bond. Fred
I think this is a hold-over from hide glue...
John in New Mexico
>IIRC, Stephen just mentioned on the hand tool board that hot hide glue needs glue application on both surfaces, perhaps to make sure it wets each surface when it is at its hottest. Perhaps he'll chime in if I've got it wrong.
Reminds me of watching some guys in one shop I used to work for trying to use vinegar to un-bond PVA - thats another old hide glue trick, which I don't think works any better than water with PVA.
John
agree on vinegar
Bill Tindal, E.TN
>I can think of no reason that vinegar would have any affect on cured aliphatic resin glue.
