OT - trick for removing latex spatter off floor
Steve Silca
>Didn't tarp adequately and I have latex spatter on my wood floors. It comes off with elbow grease and water, but there has to be a better way! Let me know your trick. Its been cured a couple days.
Re: OT - trick for removing latex spatter off floor
Jason Roehl in Mulberry, IN
>Dirtex. It's an ammonia-based, foaming window cleaner. Spray it on, let it sit for a minute or so and wipe all that overspray right off.
Goof-off also works if you get the xylene-based version.
A few days of drying is no problem--waterborne paints typically take 2 weeks to a month to fully cure, but even then, these products will still work pretty well.
Jason (pro painter)
P.S.
>It's only because I've had to clean up behind others that I know these two products work. I have NEVER gotten paint where it doesn't belong.
So, anyone want to buy a bridge? ;^)
Jason
Bill Hammond, Oregon Coast
>Had you left a good layer of dirt on the floor you could have just swept up.... Often a plastic scraper will pop them off. I use and old credit card.
Re: P.S.
nailshooter
>I hear ya. As a remodeling contractor, I have never had to clean up ANY kind of spatter, drops, overspray, drift....
Or anything else!
Yipppeee!!
Thanks for the chuckle!
Robert
BTW - when cleaning up after others, I use a soft scotchbrite knockoff and water as soon as I can. I have used the xylene based Goof Off and dissolved finish before, so never again.
Putty knife
DB
>I hope the wood floors have a good coat of finish, makes clean up so much easier. When I have to clean up paint spatters after others I just use a putty knife.
When I do the painting I just use a good brush and a good paint. Never have to worry about spatters or drips. It has been about 25 years since I bought my first paint brush for around $20.00 at a paint store (skip Home Depot and Lowes etc) and I still gives me a great paint job even after about 1000 gallons of paint. I wonder if I could still find that type of brush and how much it would cost today?
CaliJeff
>If the floor finish is fine. Let it dry, and scrape with a credit card or something like it. You may have a little ring where the drop was at this point. To remove this little drop you can use steam, or an iron on the steam setting with a towel. Test first on your problem in an inconspicuous place. This has worked for me in the past, but your mileage may vary.
Re: OT - GOOF OFF
pecker
>Goof Off is sold at Home Depot, etc. You moisten a rag with it and rub the latex off. Not too hard.
I wonder...
Ellis Walentine, Host
>...if that would work for the 20 sq. feet of white latex that spilled on our basement floor a couple weeks ago?
Dale Lenz
Re: I wonder...
Dale Lenz
>If that does not work, try the yellow can of EZ-OFF Oven Cleaner. Wait 5 or so min and take a putty knife to it. I'm assuming your basement floor is cement and is unpainted to begin with (?).
I've had great success with Goof-Off…
Rod Peterson -- Ormond Beach
>…but I've always used the water based in the spray bottle, not the xylene based that Jason recommended. The water based uses ethylene glycol, n butyl ether, and Propanol. It can be nasty stuff but is not as agressive on other finishes as the xylene is.
My experience is that it softens fresh (a couple of weeks may be fresh enough) paint pretty well—enough to easily scrape bunches of it off, then with another application, does a real good job on the remainder.
I second the use of the Scotchbrite™ but as an abrasive, one must mind the underlying finish. Good luck.
Rod
