Re: Ever hear of VirusProtectPro ?
Ray SW Ohio
>Here's the VirusProtect Pro removal process:
Download onto your Windows desktop the following Windows registry file (rem_virusprotectpro.reg). Keep it safe as you'll need it later.
To remove VirusProtect Pro you'll also need a tool called SmitFraudFix . Download this to your desktop before we begin the removal process.
Right-click on rem_virusprotectpro.reg on your desktop and choose Merge. When prompted click Yes and OK to complete the merge.
Set Windows Explorer to show hidden files.
Use Windows Explorer to find and rename the following file (rename it by adding .rem on the end of the filename):
c:\WINDOWS\system32\nuqjici.dll
Reboot the system into Safe Mode.
Click Start > Control Panel > Add or Remove Programs.
Find the entry for VirusProtectPro 3.3 from the list of installed applications and double-click to begin the uninstall process.
Follow the uninstall process. Once the uninstall process is done DO NOT allow the PC to reboot!
Check for and delete if present the following files (use the Windows search facility to search for these files):
C:\Windows\System32\nuqjici.dll
If you can't find these files, ignore them.
Check for and delete if present the following folders:
C:\Program Files\VirusProtectPro 3.3
Double-click on the SmitFraudFix file (the file you downloaded to your desktop).
Press any key to continue.
You'll now be faced with 6 options:
Press 2 to start Clean (safe mode recommended) followed by ENTER.
If you are running Windows XP you'll see the Disk Cleanup start up and clean out your temp files and Temporary Internet Files folder.
When asked if you want to clean the registry, press Y followed by ENTER.
Scan your system for malware using an up-to-date antivirus scanner.
Reboot the system. You should now be free of VirusProtect Pro.
