Resawing
Resawing
Resawing
Doug Reynolds in Seattle
>For the first time I am resawing some air dried walnut on my fairly new and hardly ever used MiniMax 20 with a newer 1" Lenox carbide-tipped blade (may have been used just one time previously for a very small job). The saw was thoroughly cleaned, a new tire installed, guides removed, cleaned and reinstalled. I lubed the blade with spray Pam. The blade is making sort of a "bouncing" or "chunk-chunk" sound as it cuts. As if it is alternating between hard and soft grain. No unusual sound when not cutting. I am using a pretty slow feed rate using the fence but, hard to feed, the wood is about six inches tall and, I am taking about a 1/2" slice at a time. The resaw cut is straight and not too terribly rough. No problem crosscutting or ripping.
Is this sound common when resawing or, is it a sign of a dull blade or other problem?
Re: Resawing
Re: Resawing
Thomas S Stockton
>Doug
The sound is must likely were the blade is welded. The weld is slightly off in some direction and makes the sound when going through the guides. A common occurence and not a problem as long as your getting a good clean cut.
Tom
Re: Resawing
Re: Resawing
jcousins
>had a similar situation on my mm16 - check the belt from the motor to the wheel pulley - mine was a bit loose sot here was some slipping - once i tightened it the "grabbing" went away.
jerry
Re: Resawing
Re: Resawing
Falberg saw Co
>Sometimes, with very hard wood and a blade that is not quite aggressive enough, the blade's teeth will slide over the wood until it has sufficient PSI at the edges to "grab"; when it does, the blade will break into the weakest corner of the kerf,(the top, because the blade is directly supported by the upper thrust support bearing which is closest to the top of the workpiece) and follow through with a vengeance until the blade is once again straight against the "wall" of the kerf. Keep feeding at that rate and the process repeats itself. The cure is a sharper OR more aggressive blade. I would favor a more aggressive blade because most blades' original "sharpness" wears off too soon.
And that is why I designed, built, and use a precision blade setter for myself and my customers. Wide set blades not only turn easier, they have a longer *effective* blade life.
I wouldn't recommend re-setting a carbide blade; so another option you might try is more tension (isn't that the cure for all bandsaw problems?) If you're already maxed out there, try jamming it hard and fast; if you don't drift or bow your kerf, the jerkiness will go away.
Re: Resawing
Re: Resawing
BilWil
>Doug, you're getting a good cut, and you're pleased with the result. I think you should put on ear protection, seriousy, each of the responses you've received are possible answers. I would look to the weld on the blade first, then I would check the belt and pulley. If neither of those are the answer, I would continue to use the blade and when I next bought a blade for resawing I would consider a blade with two to three teeth per inch.
Re: Resawing
Re: Resawing
Falberg saw Co
>If what you're now using has more than 3 TPI I can say with certainty that your blade is the problem. Trust me. Do you ski?
