Follow up to my Compressor problem
Joe in a Cleveland suburb
>Hi again.
So I took a closer look at the compressor. You can see in the image below I think "Device B" is where the problem is. The "lever A" presses up against Device B. Device B is constantly letting air out down around the little pin where the lever makes contact. I took it apart and tried to clean it. There isn't much to it really. Squirted WD-40 in it. Doesn't help. The little needle sticking out of the bottom does not look bent or anything.
This has to be a simple problem. Any more suggestions?
Thanks.
Joe
