Titebond HiPur glue cartridges
Dale Stillman
>It seems that once you use a portion of these glue cartridges, the next time you try to heat them to get the glue fluid again, they don't work. Is there a secret method as to how you can salvage a half used cartridge? TIA for the help.
Re: Titebond HiPur glue cartridges
Thomas S Stockton
>What I've done is heat it up ready for use and drill out the tip with drill bit. wear gloves and go slow but it works pretty well.
At some point the cartridges were redesigned and the new ones work a little better, make sure each time your done to srew the cap on tight while the gun is still warm this helps some also.
Tom
OK, I'm dumb. Please "Splain"
>Good Afternoon Friends,
What the heck is a hiPur glue cartridge? Haven't noticed them around here.
George
Alan Young
It's like this..
Alan Young
Hi George,
HiPur Glue is a form of animal glue-think hide glue. Only this come from Cats. As Cats have nine lives this Hi Pur Glue has an extremely long open time.
LoPur glue is also available but it come from Cats who for what ever reason have met their earthly demise sooner than their scheduled nine.
I hope this helps.
Alan
Al
Dale Lenz
Re: You got me, Alan...
Dale Lenz
>I googled hipur or whatever it's called and cat*...It's a polyurethane glue. What me gullible, Na. have a nice weekend.
Re: OK, I'm dumb. Please "Splain"
Joe Dusel (Vista, CA)
>George,
The Franklin HiPurFormer adhesives are a polyurethane hot melt adhesive that comes in a cartridge and goes in a special (but crappy) gun made by Steinel. It's a high temperature adhesive. The gun is cordless, but it must be set into a plugged in cradle until the temperature is high enough for the adhesive to flow out of the gun with trigger pressure.
The problems are first off the glue does not like to be reheated often. There is a little valve in the cartridges meant to keep the glue inside when the trigger is not pressed and this often gets stuck. When this happens if you press the trigger harder to force it the guns break rather easily. I have gone through 3 guns so far and Franklin has been very nice at replacing them for free. The adhesive tubes also have a shelf life of around 6 months after which the adhesive does not want to come out. I'm assuming it's that little valve again. Franklin will also replace those if you complain. The tubes cost around $8 each, so it gets annoying if you have only used a small amount from a tube and $7 worth does not want to come out. This is why people resort to drilling out the valve.
The adhesive is pretty good and it sets within about 30 seconds for the fastest type and a few minutes for the slowest. You can glue just about anything together with it, but it does have a bit of thickness that you need to deal with. It's great for gluing things that are hard to clamp.
Joe
Thanks Joe
>It sounds like something I'd enjoy avoiding. :<)
George
Alan Young
Alan Young
Very funny ;o)
Michael Stadulis, in Gloucester County, NJ
