Steaming Box
Steaming Box
Steaming Box
Howard
>Finally Need to do some steaming - I had heard from some that using white PVC pipe works well - can I have your comments on this please, it's certainly quicker to make than plywood boxes.
Re: Steaming Box
Re: Steaming Box
Lee Schierer - McKean, PA
>Heavy wall pvc can be used. My experience with thin wall pvc was that when you actually get steam flowing through it long enough to bend wood the pvc will soften and start to sag. PVC softens at about 150-160 degrees, your steam will be 212. I would reccomend a wooden box made from plywood or pine boards. You will need an inlet and outlet and a place for th condensate (water) to drain out.
Lee
Re: Steaming Box
Re: Steaming Box
>I've used PVC. It does sag after repeated use. A box made out of CDX plywood or inexpensive lumber won't sag. If you do go the lumber route, use stainless steel screws as other types will rust. Also, you can use stainless steel bolts or hardwood dowels to keep the material that you are steaming off of the bottom. Put them a bit above the "floor" so the steam will circulate freely and the condensate will drain out. Make sure you put a condensate drain hole on the "floor" and a small hole or two on the top. If you position your box at a slight angle with the condensate drain a little lower, this would be good.
The nice thing about sagging PVC is that you don't have to put the box at an angle :).
Re: Steaming Box
Re: Steaming Box
Bruce, a MN Galoot
>I've used schedule 40 PVC, and it works fairly well. It does sag, so I built a supporting U-shaped affair to hold its shape. Might as well have built a box.
Bruce
Re: Steaming Box
Re: Steaming Box
David Hammond, in Powder Springs GA
>Use Schedule 80 PVC - that's what Mike Dunbar uses, and it doesn't sag. Around here it's about 10 dollars a foot, but by the time you buy plywood etc., it's not too bad.
David
Re: Steaming Box
Black ABS is the way to go.
HC Sakman
Re: Steaming Box
Re: Steaming Box
Howard
>Thanks all for the input. I think I'll first try to find thick wall pvc, I'm looking for the time savings. If I can't, then I'll build one.
Re: Steaming Box
Re: Steaming Box
Kneale Brownson in Northern MI
>A well driller will have the thickest pvc you can get.
