Compressor won't quit running
Joe in a Cleveland suburb
>I know I know. I better catch it before it goes out the door...
My old compressor my father gave to me about 8 or 9 years ago, fills up with air, then does the ppssss thing until it's out of air and then starts running again. Basically, it never stops. It releases a little air then starts to refill.
It's a Coleman Powermate CH-100. I can't find any parts on line. Buying a new one is not in the cards right now. I squirted some of that super secret fix-all liquid (WD-40) into what looks like a mechanical switch. Didn't help.
Is it the regulator? Do compressors have regulators? Can I fix it? In case you didn't notice, I don't know much about compressors...
Thanks.
Joe
Re: Compressor won't quit running
Ken Oakley-Sunny St. Cloud, Fla.
>Feel around the tank for an air link especially if you haven't drained the moisture build up in the tank since you got it. Rust on the inside will eventually cause pinholes in the tank that only get bigger.If the compressor builds up pressure, shuts down and starts up again is almost always some where the air is escaping
>Thanks Ken. If I fiddle with what looks like a mechanical switch with a screw driver the hissing stops and the compressor stops though.
I'm thinking the problem is the this switch.
Joe
Re: water and dish soap
Dave Mount
>You obviously have to find the leak before you will know how to fix it. Could be almost anything from a rusted tank to a loose fitting to a hole in the regulator diaphragm.
In addition to just feeling/listening, a mixture of dish soap and water can be squirted on/around suspect places to help find it. Particularly useful for checking for leaks around fittings.
I'm assuming from what you wrote that the problem is just that it leaks (i.e., the compressor comes on an off at the right pressures, it just won't hold pressure). If not, new pressure switches can be purchased and most are not proprietary, meaning you don't have to get the original part to make it work. I replaced a bad switch on an old compressor I had -- in was just 1/4" NPT, you could put almost any switch on there.
Best,
Dave
Re: sounds like the check or unloader valve
Grant Smith
>Joe,
Most air compressors have a mechanical unloader valve on the line between the compressor and the tank. The purpose of this valve is to to relieve pressure on the output of the compressor pump so that when the unit kicks on again the motor doesn't have to come up to speed while pushing against the full pressure in the tank. Sometimes part of this valve, but more often a separate component is the check valve.
The valves can go bad, and are readily available at most industrial supply houses. Also check the manufacturers web site for parts availability. It should be a simple plumbing job to replace it.
You also might remove and examine the valves for a chunk of crud or similar preventing it from working properly. It is also possible that your pressure switch is leaking, which would be the small plastic covered box with wires going in and out. Both are replaceable for much cheaper than a new machine.
Consider the following link for more info and parts source.
Regards,
Grant in Iowa
Bill White
>Grant has the right idea. The unloader valve or the "pop off" valve is probably the culprit. The pop off on my 1978 comp. will sometimes leak a bit. I just tap it shut with my finger and we're good to go.
Bill
Unloader Valve!!!
>Good Afternoon Bill,
Give it a pill. It works for me! :<)
George
Tell us more, but I'm betting it's the check valve
Tim Greif - West of Chicago
>As Grant indicated, when the compressor stops, the unloader relieves the pressure in the tube between the compressor head and the tank. This is so the compressor isn't sarted against high pressure. This is the "pssssst" you hear when the compressor shuts off.
At the tank connection, there is usually a check valve where the tube enters the tank. It generally looks like an ordinary brass bushing or coupling but ist's actually a check valve. It allows air to flow into the tank but not back out toward the tube and compressor head. If it leaks, the air will flow backward out of the tank and continually flow out the little "pssssst" unloader until the pressure drops to the turn-on point, and the compressor starts back up. This will continue forever until you fix or replace the check valve.
If your compressor runs, shuts off, goes "pssssst" then restarts - repeating until you unplug it, it's probably the check valve. If the compressor never actually turns off, then disregard this. That's why I asked for more info. Tell us the pressure readings you get when all this is happening.
Okay
>OK, I'll get some more info and post back. Thanks guys.
Joe
Compressor thoughts *LINK*
Ellis Walentine, Host
>My hunch is with several of the others: your check valve isn't working correctly. Maybe it has a piece of debris stuck in it or something. Take it apart, then clean it or replace it.
As an aside, it is most likely that the reason my shop burned to the ground in 1999 was because of an unloader valve malfunction. If the unloader gets stuck, the motor has to try to crank the compressor against 125 lbs (or whatever your limit switch is set at) of pressure. It's too much for the motor, so it sits there drawing amperage until something gives.
In my case, the fire marshall suspected that the wires in my breaker box for that circuit had been heated and cooled so many times that the connections at the breaker were loose. A major arc developed. It blew a hole (!) in the back of the main breaker box and ignited the urethane foam insulation that I had sprayed on the foundation walls of my bank barn. The rest is history.
The moral of this story is that you never know when or where something is going to go terribly wrong, but don't take air compressors lightly. You shouldn't have any worries with your small pancake compressor, but, as a general rule, make sure your switch is set to "off" when you leave the shop. If you leave it on "auto" it will cycle at will, whenever the pressure switch says to. Our 50s-vintage compressor was on "auto" that fateful day. All I can say is be careful.
Best,
Don't let this happen to you
A side question for Ellis?
>Do you remember what brand your panel was?
As a Home Inspector I hear certain brands blamed for every thing. Just wondering if yours was one of them?
I ahve been thinking about my compressor. It has a slow leak and runs occasionally. I need to put it on a switch that gets turned off when I am not in the shop. In fact, I should turn off most of the power when I am not there.
I think it was ITE pushtronic?
>Can't recall now, but I know it wasn't Square D, which is what I have now in both the house and the barn.
Re: Compressor thoughts
>Thanks Ellis.
I never leave it on. In fact I usually have it unplugged. Fire scares me for sure.
I don't like looking at those pictures, btw...
Joe
Pressure Switch & unloader *LINK*
Curt Harms
>I have an oilless Campbell-Hausfeld. It and other consumer-type compressors use a combination pressure switch/unloading valve. When I checked my dictionary for the word "cheap" there was a picture of it! I went to grainer and got a pressure switch with integral on/off switch and a separate inline unloader valve. If You log onto Grainger's web site and put terms like 'unloader' and 'air compressor' in the search box You should get some hits. The compressor has worked fine since this mod.
HTH
Curt
Inline Unloader/check Valves
