Streaking Walnut
RP
>I've never used Sanding Sealer before. I turned some walnut bowls and put the sanding sealer on them. I sanded it lightly as per the directions and then applied wipe on Poly over it. The bowls took on a streaky look. Dark and light areas, shiny and dull areas.
The Sealer I was using was a water base poly, which says you can put poly over it after it dries.
Am I doing something wrong? I am not sanding through it. I stirred the sealer trying to ensure I got all the solids off the bottom of the can. It has done it twice to me.
Thanks.
RP
