Adirondack Chair
Adirondack Chair
Adirondack Chair
Scott S.
>I recieved my newest FINE WOODWORKING in the mail last week. This is actually a decent issue. I am looking at making a couple of the ad. chairs for our patio. Has anyone built one of these. If so would you change anything about it. Or would you leave well enough alone. I really like the looks of these.
Scott
Re: Adirondack Chair
>Scott, I have not made an AD Chair, but I watched Norm. One thing he said that "rang true" for me was that you want the arms to be level on them so that you can set a drink on the arm and it won't slide off. This might have a tendancy to make the arms feel "high" at the elbow, so be careful. Another thought is to modify the bracket that goes under the arm to include a drink holder.
AD. Chairs have a tendancy to be low slung and hard to get out of. Check out the asymetrical one that left the arm off one side for that reason. (in the same issue.)
Don Orr
>What Barry says is all true. They are low-slung and can be tough to get up out of sometimes. I have been trying to come up with a modification to raise the angle of the seat to make it easier for my wife. I found a picture recently of a different style of leg that would work-if I can find the picture again (memory not so good anymore). I did not get my issue of FWW yet.
Good luck, they are quite comfortable chairs.
Mike Southwood
>For a really comfortable Adirondack-style chair that's easy in and out, look up "Jake's Chair" on the internet. The instructions are crystal clear. I've make quite afew for myself, family and neighbors.
John in IN
>I made these 2 years ago, adapting a design by Scott Masi published in an earlier issue of FWW (May 1999 #136), and have been pleased with the result.
Another plan... *LINK*
doug f, san clemente, ca
>Scott - I've built several from this plan and have been quite pleased with the results. The chairs are a bit larger than usual and the arms somewhat wider. I find that they are easier to get up from also, but that's personal preference.
Have fun with your project.
Doug
http://www.internetwoodworking.com/w5/chair.html
kenny in indep
>Hello, I have made six of Norm's chairs. If I make any more I will put a slight angle on the arms, up, down, or sideways just so water will drain off but drinks will stay put. Chairs are a little had to get out of but when you are sitting in one you really don't want to get out. Good Luck, Kenny In Indep
Yet another plan
Jim Dillon
>Scot,
Haven't made the chair in the recent FWW, but it looks nice. I made two Adirondack chairs from cypress 7-8 years ago and like them a lot. They were one of my first "real" woodworking projects and were fun to do. My plan came from an issue of American Woodworker and was authored by Andy Rae. The major difference is in construction methods: the use of large dovetails to hold the arm assembly (and streamlining the style), mortise and tenon joints for the rear, and loose tenons for aligning the rear slats. The chair is VERY confortable (much more so than I ever thought it would be) maybe due to the curved seat portion. Good luck. Here, hopefully, is a pic of the chair and a photo of the basic construction from the mag.
Jim
Pic #2
Jim Dillon
Don Orr
>Thanks Mike, I'll check it out.
