vom meter
vom meter
vom meter
Ronald
>checking a thermostat from hot water heater. book says unhook all electrical wires and set conuitiy to rx 1. touch #1 and #2 now it says should read zero. does that mean i should hear a beep or not? hope someone can under stand this. not sure if i can
Re: vom meter
Re: vom meter
John in Ks
>When using a VOM to read resistance in ohms you should "zero" your meter first before taking a reading. You do this by touching the two meter lead together and watching the needle on an analog meter. If the needle does not go to the 0,zero, there is an adjustment to get it to read "zero". Once "zero'd" you can use the meter to take accurate readings.
Re: vom meter
Re: vom meter
Ronald
>i have a digital vom. sorry should have said that
Re: vom meter
Re: vom meter
Dale Stansbery
>It depends on the meter. Usually if they have a "continuity" switch position, then you may hear a beep when you test a circuit with continuity. Other wise use the ohm meter setting and it should read close to 0. sometimes a switch will read a fraction of an ohm across the contacts and be fine. If you're checking a long stretch of wiring by shorting the far end, then you will read a small resistance since only stuff at absolute 0 has no resistance.
Re: vom meter
Re: vom meter
Jim Swank
>Touch the meter leads together. If you hear a beep then, you should hear a beep when measuring zero ohms. No need to go into a long discussion about continuity or diode test features, or turning the tone on or off, and which meter you have.
Re: vom meter
Re: vom meter
>I think Jim nailed this. Set your meter to Continuity and touch the leads together. See what it does. If it beeps, your meter has an "audible" notice for 'continuity'. If it does not beep, watch the meter adn see how it responds.
If you are checking a thermostat and you have continuity, the switch in the thermostat is closed and current would flow and the element woudl heat (If the element is good). If you do not have continuity then the swithc in the thermostat is open and current will not flow. You may have to change the setting on the thermostat to open or close it.
You can also check the elements with the meter. Disconect one of the wires and check from screw to screw on the element for continuity. If your have continuity, the element should be good.
As a Home Inspector I check water heaters every day. I use the low tech method known as the "Thumb Test". Open the bottom panel and put your thumb on the tank. If it is hot, everything is OK. If not, and there is hot water, the top element is OK and the bottom one is out. Thermostats fail occasionally, but the most likely failure is the bottom element. It does most of the "work" and is most likely to fail.
