Computer file removal questions (OT)
>I just upgraded my Kodak Digital Image software. (If you can call removing an old piece of software and installing a new one in a meir four or five hours and going from 40 megabites to 100 megabites for what appears to be the same functionality an UPGRADE). What a nightmare.
I would like to clean up my computer, but this is a horror story for me. I decide to remove some file labeled some nonsensical thing like PDQa23z and my scanner never runs again. Sometimes it asks "are you sure you want to remove this file?" How the H@11 would I know?
My question is: There is a Zip file folder that is labeled "Rally 2" on my Desktop. I assume it is a zipped file my son downloaded. I went to Control Panel and Add/Remove software, but it does not "see" it. Can I just remove the folder With Windows Explorer?
I have numerous files that Add/Remove does see that I have no idea what they are for. How can I tell? One is "Picture Package".
Re: Computer file removal questions (OT)
Ric Taylor
Ric Taylor
>Barry,
Many times you can go to Google and type in the file name, and it will lead you to a web site that will explain what it is. I do that with any file I want to remove that I suspect might be useless and just taking up hard drive space.
Ric
Al Stokka - Cambridge, Iowa
>Barry,
Picture Package (unless someone at Sony forgot to claim a copywrite) is a Sony program.
Al
Software doesn't take much disk space
>Usually software doesn't take a whole lot of disk space relative to the large hard drives we have and the data we have. There are a few exceptions to the rule, but generally I find that people can spend alot of time trying to use the Add/Remove program feature i nthe COntrol Panel to clean up disk space and are dismayed at how little they have saved given the amount of effort it took. Use Add/Remove to imporve performance, and to remove software that you know you don't use or you know takes up alot of space.
Happy Woodworking!
Generally
>Generally, you can remove any data files, such as .doc .xls .zip files that you want to remove.
Happy Woodworking!
Dave Arbuckle, Plano, TX
>The safe answer to "Windows thinks the doWoobieZing.dll file is no longer used, would you like to remove it?" is no. You gain very, very little disk space by removing the typical DLL, and if it really was needed finding it and getting it where it should be can be a geniune pain in the DLL.
Bill Howatt
>I think you are talking about two similar but very different animals. When you go to Control Panel Add/Remove Programs it is asking you if you wish to remove installed programs. When Windows installs a program it places files in the appropriate areas and makes entries in the Registry. To get rid of the program you have to uninstall it which is what this feature does. It does NOT care anything about data files like pictures you loaded, letters you wrote, ZIP or any other file you downloaded, files you copied from a floppy or CD - you get the idea.
These non-installed data files are managed by Windows Explorer. You should never delete files in the Program Files folder because they are where the installed programs are typically stored. Other entries for installed programs will also usually be in Documents and Settings. There also may be files located elsewhere. As mentioned, the Add/Remove will normally take care of locating and deleting them.
Bill
Why bother; what's gained?
Lee Gordon
Lee Gordon
>"Sometimes it asks "are you sure you want to remove this file?" How the H@11 would I know? "
I hope this doesn't sound too much like a wise-a$$ answer, but if the computer asks if you are sure you want to remove a file and you aren't sure, the answer is "No."
Bill Howatt
>When I see that question, I always say to myself, "I was until you asked!".
In the old days, you could look at a file name and type and have a reasonable guess at what it was for. That as long since changed so when in doubt, leave it alone. Another problem is that very few people have a good backup of their computers so if something goes wrong they may be in deeper trouble.
Bill
Old habits die hard
Ron in Drums PA
>I remember when my first harddrive was a whopping 10meg. I thought I would never full that sucker up. It didn't take long before I had more files on there than I knew what they where. Today my main system has two 500gig drives. In the old days of DOS, it was easy to figure out what was important and what wasn't. Today it's not that easy
Just deleteing files can cause major problems, "Is this important?" Who the heck knows anymore. Also there are some leftover entries in the registry that can cause minor problems.
I started using this program not to long ago and love it. Your Uninstaller It has some really nice features. One is that it will search for orphan files and entries and will give you the option of deleting them or moving them into a separate folder, just in case to need to retrieve them. Screen Shots
Another program I like to use is called CCleaner
IMO, a clean drive runs faster.
BTW, once you are done cleaning up your drive, it's a good idea to defrag it too.
My procedure
Curt Harms
>When I get these messages, the message indicates in what directory the file in question is located. If the file in question is in c:\windows\something_or_other, I leave it alone. If the file in question is in c:\programfiles\deleted_program I delete it. That's worked so far.
HTH
Curt
