Have a question? Ask Woody!
cellulose sand and sealer
Steve Hoyle
>what is cellulose sand and sealer? Is Mylands the only manufacture?
Re: cellulose sand and sealer
albertabob
>Most of them are cellulose in a lacquer solvent with a sterate added to fill the pore in the wood. This is an over simplification but it genreal cover most sanding sealers that involve lacquer.
It is my favorite sealer after the last sanding pass as it raises the grain a bit while filling in the pores making the next rubdown a snap. the lacquer solvent carrie the sealer deepinto the wood.
I will usually switch to 3M pads of similar after sealing and continue with staining or finish coats.
There are many on the market -so far.
I use one from Colverdale paints up here.
Do a google for "sanding sealer".
Bob
description
Michael Dresdner
>I think you mean sanding sealer, which is clear finish, often lacquer, that usually has added inert solids to help it build faster and sand more easily. One of the solids commonly used is ethyl cellulose. My guess is that whatever label you are reading is indicating that cellulose is one of the primary build agents in that particular sealer. Other common ones include zinc stearate and fume silica.
