Where Hardwood Lumber Comes From 9-steaming walnut
Bill Tindal, E.TN
>Part 9 Processing Walnut Lumber
Every pack of commercial walnut lumber that I ever saw for sale was steamed, a controversial practice among armature woodworkers. In this part I will show that the fretting over steaming is unfounded.
The sapwood of walnut is white and most woodworkers and all furniture factories find it an unattractive addition to furniture made from walnut. Most of the good walnut logs go for veneering. The highest grade lumber is on the outside of the log. When small logs are sawed the clearest lumber will have a lot of sapwood (recall that sap is not a defect by NHLA standards). Hence, the practice of steaming was developed to almost turn sapwood into heartwood.
It has been found that when fresh cut walnut lumber is heated in wet steam that the sapwood turns nearly the color of the heartwood (when it is done properly). This process is called steaming. A very large walnut steaming operation was located near where I lived and from working with them on a couple of problems I thought I knew about steaming. Just before the death of Jon Arno I argued with him about how steaming works. I lost and in his memory planted a walnut tree on the farm. Some spring I will post its picture as a reminder of Jon, but I digress....
The process does not involve diffusing pigment from heartwood to sapwood. All that is required to properly steam is to get the sap wood to a temperature around the boiling point of water in the presence of wet steam and the sapwood will turn black. You can do the experiment in your pressure cooker. (more on that later)
A typical steamer is shown in this picture. The silver things on each side are huge aluminum doors, aluminum because the iron doors corroded away in a few months from the wood extracts. One �dead pack� of walnut has been put in the steamer. A dead pack is a pack of lumber with out sticks between the layers. Once this chamber is filled with packs of walnut it will be shut up and steam from a boiler introduced for a couple of days until everything is hot and soggy. A pleasant odor of furfural seeps out of the steamer indicating some decomposition of the cellulose. A furniture factory owner told me that steamed walnut processed better in his factory, perhaps due to some alteration of the wood during steaming.
What went into the steamer brown and purple and white now comes out of the steamer looking like it has been blackened with soot. This change is the objection of many amateur woodworkers. Their complaint is that kiln dried (really steamed) walnut looses it color character, and they are correct. Once the soot is planed off the walnut will be a uniform brownish-black. How ever this difference is irrelevant in the long run. Continued in the companion post below
Re: Where Hardwood Lumber Comes From 9-steaming walnut
Re: Where Hardwood Lumber Comes From 9-continued
Bill Tindal, E.TN
>Most woods get darker with age, but walnut gets lighter unless it is stained (which is why I always stain walnut). Walnut will become almost blond after years in a sunny room. This picture shows two pieces of wood split from the same air dried plank. One was steamed in my pressure cooker, the other was not. At time zero the steamed piece was almost black. The other piece was shades of lighter brown and purple.
This picture shows these pieces after a few months in my sunny dinning room. In the best light I can still detect slightly more black in the steamed piece. Forget the purples in the air dried piece, they left almost immediately upon sun exposure. I will leave it to the reader to judge if it makes any difference whether one uses air dried or steamed walnut in their projects. There will be a lot of difference in the sap wood, of course.
Dave Winters
>Bill-
First off, thanks for this series, very interesting and informative.
I have seen older walnut jobs where the wood is exposed to UV, and just like you say, the wood is all bleached out. But inside say a cabinet door, it's still dark.
I never would have considered staining walnut, seems like sacrilage, but where it's going to have a lot of sun it sure makes sense. Do you use a stain or dye or what? What color?
-Dave Winters
As we speak!
Bill Tindal, E.TN
>I just came from the shop to eat lunch and ck mail. I have been staining the walnut chest I am working on. I use pigmented stain- burnt umber or burnt umber with something to tone down its redness. Of late I have been mixing my own stain. I will post in a day or two my staining procedure and a PIC of results. When sanded right the appearance is clear and it brings out the grain and highlights while avoiding the yellow bleached look it can get with time.
Myra in TN
>I may have missed the answer to this question and, if so, I'm sorry for bringing it up again.
Are these "Where Hardwood Lumber..." postings being saved as articles for easy reference in the future? I'm finding them very valuable.
Short answer—yes!
Rod Peterson -- Ormond Beach
>The actual mechanism is on hold at the moment. I'm the one who will actually convert the article to HTML along with the pictures for inclusion on the WoodCentral Articles page (already have an article number assigned), and I've been saving the material as we go along. Bill wants to edit the installments as a whole when he's finished producing it first, though. I suspect there will be more collaboration than just those two steps, however.
Rod
be assured
Bill Tindal, E.TN
>I will cooperate with the staff of WC to get the material assembled into an easy to read article.
Clay Foster
>Bill,
I've really enjoyed this series. Thanks for all the effort you've put into it.
Are sawmills as noisy as they look?
Clay
answer- modrate
Bill Tindal, E.TN
Moderate. There is a lot of Varooommmming from the diesel engines in the log and lumber moving equipment. The head saw makes a whine that I suppose is from the saw plate vibrating. It isn't loud. Conveyors hum and the dust chain clanks. The gang saws are loud as many saws are cutting simultaneously, but this noise is intermittent. The booth where the sawyer sits is quiet and they often have a radio or other distraction.
It isn't hard to have a conversation around the mill.
