Electrical problem - OT
Mark inb'ham
>A while back someone posted about a burnt electrical plug that was using the quick push in things in the back instead of the screw contact on the side. A lot of people said that they have had problems with those things. Well, the lights in our upstairs bathroom just stopped working, I checked the bulbs, they were okay. I checked the connections to the light fixture, which I put in a couple of months ago, and it was okay. Then I looked at the switches, there are two at each door (it's a jack-and-jill bathroom), and they were all wired through the push things on the back (I wish I know what they are called).
I want unwire the the switches to test them, but I am wondering how to get them apart. Am I better off cutting the wires and just rewiring on the side with the screw? Or should I just cut them off and scrap them completely? The switches may be the problem anyway. What do y'all think?
TIA - Mark
Re: Electrical problem - OT
Larry Clinton At Frankfort (Central)., Indiana
>The "push in connector" has a hole or slot beside the wire. With the power OFF, you can push an object into that hole and it will open the push in connector - releasing the wire. If the wire is not burned, badly discolored etc., you can either wrap the wire under the screw adjacent to the "push in connector" and tighten it down or assemble it to a new switch in the same location.
Bill Howatt
>Did you check the breaker before you do all this other stuff?
I had a GFI which the lights were wired from downstream when it tripped the lights naturally went off too.
Bill
Mark inb'ham
>Yup, checked the breaker first. I am unaware of any GFI downstream, but it could be there. Thanks for the suggestion.
Rod Peterson -- Ormond Beach
>I've always heard them called back stab style. Generally, you can consider them to be lower-end fixtures and I wouldn't hesitate to replace them altogether, rather than rewire them. I had some in my house that didn't even have screw terminals—they were 100% back stab. They're no longer on the premises.
There are fixtures that have a back clamp feature which should not be confused with back stab. One inserts the stripped wire into the hole and then tightens the side-clamp screws to secure the wire. It's just as good or better than the usual side clamp wiring.
I have a small blade screwdriver that I keep in my electrical tool bag whose sole purpose is to pry the spring clamp loose in back stab connectors. I always do that just before I throw the things as far away as possible.
Rod
Randy Johnson Connersville, IN
>If I understand correctly there are two three way switches at each of two doors to the bathroom.
Nobody has mentioned this yet, but you want to make sure you know where each wire is connected on the existing switch before you start installing the new one. A three way switch will have two bright screws and one that is almost brown. The two bright ones are for the "travelers" and the brown one is for the common. How the screws are placed on the switch will vary from one brand to another so it isn't a matter of just putting them on the same as the old one - you have to pay attention to the colors of the screws.
Usually red and white are travelers and black is common but I've seen every combination imagineable.
Thanks for the help
Mark in B'ham
>It got too late last night to fix the thing, so I put everything back together and plan to tackle it this afternoon.
Done
Mark inb'ham
>And I did it without any electrocutions. Replaced both switches and everything worked like a charm.
