Re: OT --- installing wood floor
Jim Dillon
>Jim,
Can't add much to the good advice you've gotten. Another option is to screw and plug the wide boards, but if they are all 4 inch wide, that might give you a rather "busy" looking floor, plus that lends to a more rustic look (which may not fit with your friends decor), and lastly, the floor installer might not want to put in the rather labor-intensive effort; personally, I love the look of the floor plugs. Bollinger's book mentions face-nailing or screwing plank flooring WIDER than 4 inches (no mention of adhesive use). So you are kinda in the middle. My gut feeling is that if the wood is well dried, acclimated to the house, and there are no household moisture problems, regular tongue-and-groove nailing should suffice. Speaking of which, you didn't say if this flooring was normal tongue-and-groove flooring or just planks. If the latter, then I would go with face-nailing or screwing; I don't think adhesives would be needed. Keep in mind, I'm just a DIYer, so my advice is worth what you are paying for it 8-).
As an aside, there was a thread on wood floor movement (or non-movement) a day or so ago that might be of interest to you. Good luck.
Jim
