PC557: sloppy buscuits
Bob McGovern
>Been having some trouble getting my 557 to cut consistent-gauge slots or maintain proper alignment during the compression stroke. Anyone else here experienced that? Then, recently, it began binding on the in & not retracting properly on the out stroke. The sliding surfaces were clean and lubed with graphite, but I was getting improper-depth slots & kickback when the tool would bind and suddenly release, diving into maple at high speeds. For a tool used in indexing parts and relying for joinery strength on tight tolerances, this is an obvious problem.
Equally obvious is the cause of the problem: the motor unit slides in a keyway -- both bare aluminum. Which builds up oxides, which act as grinding compound, which leads, after many cycles, to slop and binding. Duh. (Doesn't the Lamello have bearing-equipped ways?) PC's 'gibs,' if you can call them that, are not built for tightening as wear occurs.
Two years of occasional use seems a short life span on a $250 tool. Called PC, then regional service rep. Both hinted they were aware of the issue, but wanted $125 plus shipping & tax to repair it. Lovely. It's your design flaw, PC! How about addressing it at your own cost?
So, having nothing to lose, I picked up a hammer. (This will end in tears.) Found judicious peening of the keyways with a centerpunch or nail set will remove the slop from the slides. Trying light machine oil to fend off future oxidation; hope it doesn't get onto the wood. So if you have a balky PC577, it's okay to hit it with a hammer. G'won. You'll fell better. And save a bundle of money.
