23 Ga pin nailers
23 Ga pin nailers
23 Ga pin nailers
Howard
>Have aneed for one now, currently have Senco 18ga brad nailer. I've heard some very good reviews, but also hear thatthe nails are not countersunk and that jamming ccan be a problem. Can I have opinions please
Thanks for reading.
Re: 23 Ga pin nailers
Re: 23 Ga pin nailers *LINK*
Dom Russo
>Howard,
I recently purchased a GREX P645L, which nails pins from 1/2" to 13/4" flawlessly and has a lock out feature when you're low on pins. It is really well made and has not misfired in the 500 or so nails I've shot so far. Grex has some less expensive models if you don't need the long pin lengths or the low pin lockout features.
Good Luck,
Dom
Grex 645L
Ross
>I have the Senco. I haven't had any jams.
>Good Afternoon Howard,
We have the Senco, a P+C, and Harbor Freight pinners in the family. I personally like the ergonomics of the Senco #1 son has. It is older, and will not fire a complete stick of pins. That is why #3 son replaced it with his new P+C. My Harbor Freight works as well as either of the others. Cost differential is noteworthy.
George
Second the Grex
Henry Higginbotham
>I used to have a Senco, which I've since given away. I bought a Grex at the last WW show. Wow--big difference. The Grex DOES sink the pins and just generally feels like a better gun. For the price difference I suppose it should, but ya get what ya pay for.
Pinners don't have nose safeties, which means you can point them at the wall and shoot a pin across the shop. With the old Senco, by the time it got to the other side of my shop, it was kind of like I'd just thrown it at the wall. With the Grex, I quickly decided that might not be a good idea--you hear the pin ricochet several times. The Grex does have a trigger safety, which most cheaper ones don't have.
And I'd highly recommend the show vendor, Jerry Carter Air Tool Supply. Nice folks to deal with.
Hank Knight
>I have a Senco 32 Ga Pinner. It doesn't drive the pins flush or countersink them - very disappointing. I've had no jams, however.
Ray SW Ohio
>I have a Senco and had no problems, it just sets the pin below the surface though.
Bill White
>Got mine from Toolsmart. $59.99, and it works just fine. Had it for a year w/o a single (watch that change tonight) jam.
Bill
BilWil
>Grex and Cadex are the two that get the highest marks in the reviews and from the finish carp's I work with and around. Get the one that you can get parts for, I don't care how good it is you'll eventually need a driver, or something because you dropped it. I have used both and like them both, I ended up with a Grex because my supplier carries it and not the Cadex, I would have had to drive 22 miles to get the Cadex.
Bill Sams
>I've had a cadex (same as grex) for over 3 years. No problem with jambing or sinking of nails. Had to replace the gasket on the top of gun as it was leaking air. All in all 23 guage nailers are worth every penny as they require no filling of holes.
Larry Clinton At Frankfort (Central)., Indiana
>Hard to beat the Harbor Freight price - I paid $12.49 + shipping. Although I have only shot 100 or so pins, it hasn't once miss-fired or jammed. It has the safety trigger and it does set the pins well below the surface in white oak using 1" pins. However, it is limited to 1/2" to 1" pins.
Howard
>Thanks for the opinions, the Grex is a bit pricey but I will order this one. Thanks again.
BilWil
>You'll be pleased with the Grex.
