Wax On Wax Off I Goofed
Dustmaker Mike
>Ok so there I was putting the last coat of Poly on a table top when all of a sudden a little Bug landed in it. So I think to my self that it will be OK because I have one more step to do to finish the top. So here is where I messed up. I wanted to polish the top a little more and give it a slick surface also get rid of the bug. I grabed the Steel Wool and applied a coat of wax to the top,I then went to buffing it out with a car buffer all of a sudden there where scratch marks from the steel wool on the surface (not all over but just in spots) I looked at the steel wool I grabed and it was course instead of fine.
So how do I get the wax off so I can wet sand it and apply one more coat of Poly. Then leave it alone after that.
Re: Wax On Wax Off I Goofed
Larry Clinton At Frankfort (Central)., Indiana
>Mineral spirits / paint thinner will remove the wax. However, I would check the existing finish with the MS in an inconspicuous spot to be sure it is cured and that the mineral spirits doesn't soften it - If so wait till its cured. I would clean it several times with a clean towel or cloth each time to insure all wax is removed and not just moved around.
Or Use Naptha
Re: Or alcohol
Dave Bair, Eaton Rapids, MI
why another coat
Bill Tindal, E.TN
>Why can't you wet sand what you have and buff it back . that is the way I do my urethane finishes. I don't see the need to recoat, especially given the likelyhood of not getting all the wax off, fish eyes and a death sprial. Grind glass smooth with 360 or 400, and buff back with pumice or rotten stone.
Fish Eyes Yuck
Dustmaker Mike
>I like the idea Bill I will just use the 400 grit and jump to 600 then Rotten Stone. Thank All the Advice folks.
