shellac finishing
john pohja
>Anyone ever had problems removing residual shellac dust after light sanding (up to 600 grit) of a sprayed-on shellac finish? I waited 4 weeks to let the shellac cure, and as Jeff Jewitt's book recommends, used a cloth dampened with mineral spirits to remove the residue; thats the way i've always done it, with good results. However, on this project, after the wiping-off i get a whitish, filmy, haze as though the mineral spirits just moved the dust around and then dried. This is a very dark mahogany finish so the haze really stands out. I've wiped the piece down twice and only some of the film disappears. Do i continue to wipe with MS? I'm afraid that too much MS may damage the finish. Is there a better method and/or chemical to remove this residue? Thank, John
