Rebuildng Nail gun
nailshooter
>Barry: Depending on the gun you have, you may be able to get repair parts over the net. As a contractor, I rebuild my guns as needed, and rarely have problems with them after a rebuild.
The thumping noise is probably due to a blown cylinder gasket. IF this is an oiled gun, this is an easy fix. With the right sized "o" ring (or rings) in hand, take the head off the gun. Turn it upside down and tap on the gun over a table until the piston falls out. You will be able to see the damage to the "o" rings on the cylinder immediately.
Remember, you CANNOT use regular lubricants on this and must use specially made lubrcants designed to work with the "o" rings without dissolving them. If the cylinder is clean, do not clean the inside. Do not shoot WD 40, Tri Flow, graphite, or any other lubricants in the cylinder or on the piston. Buy the correct gun oil at the tool store and use it on the "o" ring before reassembly.
My rebuild kits for my Bostitch guns are about $35 for soft parts. Drivers are about $75, and triggers are about $35. I buy those straight from Bostitch or on Ebay. Soft parts shouldn't bee too much for your oiled guns.
On my generic branded guns, I bought some neoprene washers in a 500 piece assortment pack at Harbor Freight and look like they will do the trick for them as they are shop guns only. So far, so good.
Robert
