UV window film
UV window film
UV window film
david b
>Does anyone have any expierience with this stuff. I have 2 west facing window that are letting in some heat. I have put up blinds but I was wondering if this film would help even a bit more.
thanks,
db
Re: UV window film
Re: UV window film
>It can work, but be careful. If you have (IG) Insulated Glass (Thermopane or double pane) windows it can put the seals at risk. The film heats the glass, causing it to expand more than the other pane stressing he seal. (Thermopane is a brand name and is glass that has been rolled att he edges and bonded glass to glass and the selas are tough and unlikely to fail. Insulated glass has seals that are bonded or glued with caulking like material and will eventually fail.) Stressing the seals on IG units is not a good idea.
You might look into replacement sashes with the coating built right in.
Re: UV window film
Re: UV window film
Ray SW Ohio
>I put up solar screens that really helped me. The material I put up blocks 80% of the sun's rays. You can get it up to 90% too. I get the morning and evening sun on my house. I actually can see a savings on my electric bill since I put them up. My 2�.
Re: UV window film
Re: UV window film
riag in Silverdale
>You might also keep in mind that window films will void your warranty.
Re: UV window film
Re: UV window film
Phil Thien
>You learn something new every day. Are "real" Thermanpane windows substantially more expensive than insulated glass?
Re: UV window film
Re: UV window film
albertabob
>I have used this stuff commercially for more than 25 years on my warehouse. I have yet to have a seal go on the windows.
I have had some windows go as a result of vandalism and each time we replaced them with reflective " UV" resisitant film.
You can buy small quantiies at most hardwares stores or have it applied by you installer.
p.s. they do make the inside a bit darker.
Bob
Re: UV window film
Re: UV window film
Bill Howatt
>I bought the stuff Lee Valley was selling around 7-8 years ago. It works very well but does make the room a bit darker and the effect on the A/C is very noticeable.
I put it on "thermopane" windows with no problem but like it says in the instructions you must put it on the outside not the inside!
My friend put it on his daughter's skylight and couldn't believe the difference it make to keeping the house cooler.
Since our temps range from an unofficial +100F in the summer to -40F in the winter, the film gets installed in the spring and removed in the fall. I clean the window with glass cleaner, spray the window and the film and then squeegee it out smooth. Stays perfectly stuck on the glass all summer and in the fall I peel it off, roll it up between paper and put it away for next spring. It clings to itself but spraying with cleaner releases it, avoid windy days!
The LV kit came with instructions and a small squeegee; I have no idea if they sell it anymore. I think it was the size for a patio door so I had to cut it. I've been told it is the same stuff that they use for tinting car windows so that may be a cheaper source for the material.
Bill
Re: UV window film
Ric Taylor
Re: UV window film
Ric Taylor
>I had some film that is made by 3M installed professionally in my home three years ago, and I love it. It is installed on the inside, where it is supposed to be, and it does not affect any warranty.
Not only does it keep my home substantially cooler in the summer, but it greatly enhances privacy, as it makes it difficult to see in from the outside during the daytime.
Ric
Re: UV window film
Re: UV window film
Curly Smith
>No recent experience but I installed some in a house 25 years ago. Similar situation to yours, west facing windows and mini-blinds. During the late afternoon the mini-blinds were warm and the metal window frame was too warm to comfortably leave your hand on. Installed the film and the room (and the window) was much, much cooler. Of course, window technology has vastly improved since then. In short, the film will keep the UV and heat out but I can't comment on whether or not that's bad for your window.
Re: UV window film
Re: UV window film *LINK*
albertabob
>I Hae use this one sucessfully for 25 years.
Hila UV film
Re: UV window film
Do you mean the thermal reflecting stuff?
>If that is what you are talking about, then I have it in the window of the room I am in right now.
It works quite well and I would not be without it. There is a caution though. The older stuff would damage thermo pane windows. I am pretty sure that stuff is still around. Make sure you get film designed for thermo pane windows or you make find the window cracking on you.
It REALLY reduced the heat in my home office a LOT. I have an East facing window and it gets sun most of the day. I immediately noticed a difference.
I do not know if it specifically reduces UV or not. Likely it does.
Re: UV window film
Re: UV window film
>There are (were) two brands of it out there I think, Thermopane and Twindow. Andersen used to be the only manufacturer using Thermopane on a regular basis as far as I know. Emphasis on "as far as I know".
I think it would be significantly more expensive, but I don't actually know. I'm sure Andersen or a big user could get a good price, but it got to be outrageous for custom units. Its basicall a flat glass bottle with a tiny hole left in it. They filled it with nitrogen and sealed the hole.
I can't recall ever seeing a fogged "Thermopane" unit that was not physically damaged. (I'm a Home Inspector and I see a lot fo windows). I see failed IG units every day. Almost literally and I certainly average seeing them daily.
Andersen has gone to using IG units because they wanted to use Low-E glass. This stuff has a "film" or layer of metal placed on it in some high tech fashion that is so thin it is almost perfectly transparent. It is selected or "tuned" to reject UV. I think it is possible to have it made to reject IR, but I am not sure. You could have windows that reject or block UV but reflect IR back into the house. Lots of possibilities. The coatings ar fragile and must be on the side fo the glass inside the IG unit to protect it from abrasion.
IG units are typically made in Five year or Ten year versions. I see so many that fail and fog I am skeptical about the energy savings. Does a single unit save the $150 it costs to replace it?
I have talked to Andersen about this and expressed my skepticism. They tell me they are taking pains to make the grooves in the sashes deeper to keep the sunlight and to some extent the temperature swings off the edges. Time will tell.
Re: UV window film
Re: Do you mean the thermal reflecting stuff?
Bill Howatt
>I think the post is not labelled the best. It specifies UV but the real problem is heat.
Bill
Re: UV window film
Re: UV window film
Doug Reynolds in Seattle
>David: I second the vote for 3M window Security film which is available in a variety of tints and UV ratings. It is self-adhesive and is applied to the inside of the window. Sort of a quick and dirty DIY security glass. My local distributor has a $150 minimum but, that may do several windows. 3M cannot be torn by my bare hands but, some other brands can which is one reason to go with 3M.
