OT Question On Breath anilyzer interlock on igniti
>A friend was trying to have one of the ignition interlocks on her son's car. (he had a beer induced ignancy)
The shop removed the cowling (housing) from the steering column and then anounced the car would not start. The car is a 95 Pathfinder. The car started and ran fine when they took it to the shop. She has tested the starter and solenoid and they work fine.
Does anyone have any idea what to check next and what they might have done to mess up the car?
Re: OT Question On Breath anilyzer interlock on igniti
>The key just clicks. The starter and the solenoid worked with a bypass, but the car does not start. The technician claims he had done nothing more than remove the steering column housing, but the car had not had any problems or hesitations before this.
Stuart Hough
>Barry, have them check to see if the wire to the brake light switch on the brake pedal arm has gotten knocked off. On most autos manufactured after 1992 the brake lights must work or the car won't start. I had this problem when my car was serviced. We (the mechanic and I) found that when you are fumbling around looking, with your hands, for the diagnostic pigatial, that it's real easy to mistake that wire for the one you really need.
Just a possibility....
>If the solenoid clicks, but the car won't turn over, put a charger on the battery for a few hours. I bet they left the door open while they did the work and the weak battery dischaged because the courtesey lights were on, enough that it won't start the car.
Lee
