Way OT anyone ever convered a clorinated pool
Steve in Fresno... Go Dogs
>to salt water? My sister has a salt water pool, but her's was new construction. Mine would be a conversion.
Thanks for all info.
Steve
Re: Way OT anyone ever convered a clorinated pool
Jim Shaver - Oakville, Ontario
>Hi Steve,
Mt neighbour two houses over just did that this spring, not sure of the details but he did have to turn over the full volume of water in the pool, if you like I can ask him any questions you might have. My daughter was over swimming there last week and she said she loved it!
Take care,
Jim
>What are you converting it to? I switched my pool from chlorine to Bacquacil. It's fairly easy and takes about 48 hours. You do not have to change the water.
Rick in Colgate, Wi
>We have a salt water pool.
You will need to buy a chlorine generator which has to be installed on the water return line after the filter, it also needs an electrical outlet to plug into.
Depending on the size of the pool you will have to add maybe 200lbs of salt to the water, more salt will not hurt anything.
Google salt water pools and chlorine generators and you should find all the info you need.
