Norm, Sat June 23, staining technique?
DeepWoods in MN
>Hey there fellow woodworkers,
I caught the second half of New Yankee Workshop this morning. I believe it was a rerun, but I found some interesting info at the shows end. He gave a quick formula for the staining process which he said, "...we all know." Yeah, right! While I was grabbing a pencil I missed a step.
The process for sealing up his chair consisted of five steps. Start with oil base stain. Let it dry 24 hrs. Then shellac. I've never used shellac. What's the advantage of this? Somewhere in the middle was gel stain, which I know helps blend the color in two adjoining pieces (or species) of wood which have a slight color difference. I caught step 5 which was using polyurethane. I don't think two coats of poly made up anything more than one step, so I missed one in there somewhere.
If anyone caught this show, or knows his process, I would appreciate a pointer. Thanks.
Re: Norm, Sat June 23, staining technique?
Tim Caley - North Little Rock
>Was it an oil or water based stain? Shellac can act as a seperator between oil and nonoil based products. It could also be acting as a sealer to keep the gel stain from penetrating into the wood. The stain itself would not have sealed off the wood defeating the purpose of using the gel stain to even out the color.
>Good Afternoon Deepwoods,
The purpose of the shellac is to seal in the oil stain and prevent it from bleeding into the gel stain. Thge gel stain is a surface application which will help unify the color and tone of the piece.
George
John Pappas
>Going backward...the get stain was being used as a glaze. By definition, a glaze is a layer of color between layers of topcoat. Thus the shellac...to seal in the oil stain and provide a layer of topcoat. Apply the gel stain over the shellac, then wipe most of it off, leaving just a thin amount of the gel stain. If you don't like it, you can use mineral spirits to clean it completely. Then, I am guessing, he applied another coat of shellac to seal in the glaze and then topcoated with poly.
Rod Peterson -- Ormond Beach
>What was the project? I can look at it from my archives and copy down the steps and get back to you. Was that on DIY? If so, it's a Season 13 project. If it was on your local PBS, it was almost certainly one of the last four years' projects. I have all of those, in any event.
Rod
John Pappas got it right, but...
Michael Dresdner
>there really is no need to add another coat of shellac over the gel stain glaze unless you are using waterbased polyurethane. For oil based polyurethane you can omit the second shellac coat. Incidentally, any shellac coat should be dewaxed shellac, such as Zinsser SealCoat, not Zinsser Shellac. Both are pure shellac, but SealCoat is dewaxed.
shellac, oil polyurethane, drying time?
DeepWoods in MN
>The project was the side chair, item #0507. Shown on PBS.
Thanks everyone for the great insights on the staining process. I typically do oil based stain followed by oil-based or water-based poly, depending on the wear needed. It seems water-based poly makes a good tough top for my endtables. It sounds like I should add a can of shellac to my shelf of staining supplies.
I'm working on a trim/window job; part is pine: sanding sealer, oil stain followed by oil poly; other part is oak: oil stain covered by oil poly. Any suggestions to make this end result better? It's taking the poly a while to dry in our humid MN air. Suggestions to decrease drying time? The paint dealer said to use the oil poly on the windows since they are likely to see water in their lifespan.
DeepWoodsDave
Re: drying time...
Glenn Madsen near San Francisco
>I'd likely cut the oilbased poly by 25% with VMP Naptha, and plan on several coats. Cuts the dry time way down, and makes the application easier, at least for me. I generally wipe on this mix with a clean rag, like an old tshirt.
But then, I live in California, where they reformulate the finishes, and we never have serious humidity, really. May be different in Minnesota.
R. Lance in GR, Michigan
>Generally, the routine is water-based dye, a coat of de-waxed shellac, oil based stain/glaze, and a top coat of finish (which for Norm is poly).
