Help for Delta Unisaw mobile base problem
Steve in Jobstown, NJ
>Hi folks,
I have a new (less than two years old) Delta Unisaw with the 52" fence and table extension. The unit is on a mobile base that has fixed wheels on the saw end and one center caster that is activated by a cam lever which lifts the table end of the mobile base off of the foot pads. This enables the unit to roll and be moved.
I built a small 3/4" plywood, three drawer, cabinet under the extension table to hold saw related accessories. My probelm is that the weight of the cabinet is such that when the lifting cam is activated on the center caster, the table end does not lift high enough to raise the foot pads off the floor. The saw does not move. I have a small shop and this is a big problem.
Has anyone experienced a similar problem with their Delta Unisaw? Is there a solution other than removing the new cabinet? Is there an alternate method to lift the table end of the mobile base so the saw can move? I was thinking about some type of casters that I could mount on the mobile base that could lift the saw enough to roll, but I don't know where to find such a unit. Does anyone have any suggestions or has anyone solved a similar problem?
Thanks,
Steve
