Bandsaw Motor Power Loss
Dave Winters
>Dumb Question-
Seems like my Bandsaw (Laguna LT-18) motor is more and more gutless. Takes longer to get up to speed with no load and loses power easier when sawing under load esp. sawing thick and/or wet stock, even with a fresh new blade.I do have a fair number of hours on it.
I guess my question(s)are: does a motor lose power like this before total burnout? Should I upgrade to a bigger, badder motor? Three phase is not an option. Recommendations? Laguna is hideoulsly expensive on parts in my experience.
Thanks in advance...
Re: Bandsaw Motor Power Loss
Check the belt
Lee Schierer - McKean, PA
>Motors don't lose power over time. Most likely your belt is loose or worn. After sawing carefully touch the motor drive pulley if it is really hot, the belt is probably slipping.
Check the blade guides adn see if they are set too tight. You should have .003-.005" of clearance (some people use a dollar bill wrapped around the blade to se tthe guides.
Check the saw for binding, disconnect the drive belt and turn the saw wheels by hand are they easy to turn or hard.
My money is on the loose belt!
Lee
And Pulley s' Set Screws/Keys
Larry Clinton At Frankfort (Central)., Indiana
>Electric motors do not "lose power". They put out the same HP when new - till the windings fry. (then they quit completely). A bad starting switch or cap may make them not start or run - but if they do they put out 100% of their hp. The only things that will cause the issues you describe are: 1) the belt is loose not transmitting the motor power to the drive wheels. 2) a pulley is "loose" - meaning you have a broken "key" and / or loose set screws - again not transmitting the power to the drive wheels. or 3) you have one or more bearing binding or the blade is binding in the guides. (using up the motor power)
I would first check the belt then the pulleys - then disconnect the saw and rotate the wheels by hand - checking for any bind. If you have a "bind" remove the blade ( after checking the guide settings) and rotate each wheel and the motor by hand - checking for binds. You should be able to isolate the problem and correct it pretty easily.
Scott Crumpton
>If the motor has a capacitor or two, that may be your problem. A failing start cap will slow the startup until it fails completely and the motor won't start. A failed run cap will also affect the start by slowing it down and may make the motor less powerful by altering the internal phase relationships of the windings. Replacing the caps is simple and low cost.
Dave Winters
>Thanks, all.
It was the belt, just as you all thought. Needed tightening. It doesn't slip now, but it "flutters" at full speed. Should I tighten some more?
Again, Thanks
-Dave
