Have a question? Ask Woody!
OT: Calling Lawn experts
Mark Kauder, Phenix City, AL
>Living in the South, certain areas of the landscape around the house can remain damp for extended periods.
I have a couple of North facing walls of the shop and the house that keep direct sunlight off decent portions of the yard. These three places all have some nice green moss growing. I also have some new grass started in the area.
What can I do to kill the moss, without killing the new grass? I have heard that the moss will only grow because the PH is too high or too low (I forget which).
Anyone Know?
Mark
Re: OT: Calling Lawn experts
Al Stokka - Cambridge, Iowa
>I can't remeber the pH thingie either but, adding lime helps with the moss problem.
However, the better fix is to slope the soil to allow water to drain. Less water, less moss. Better for the grass, too.
Al
Bill White
>You didn't note anything about shade trees. Gonna have a hard time growing ANY grass in heavy shade. May even want to think about some type ground cover instead of grass (lawn variety).
Bill
Mac
>Mark.... Best solution:green cement......
>I think the lime is a good idea. Land that comes out of the woods is usualy acidic. I also think moss tends to grow on poor wet soil. Try nitrogen to the max you can stand. Might be good to use a little starter fertilzer to give the grass a little kick. I have forgotten which of the other two main ingredients in fertilizer is the one that helps the roots.
If there are nearby trees you could take and old drill bit and drill holes aobut a foot deep and fill them with fertilizer. Drill a grid of holes aobut 2' OC. I ahve a large tree and I put about a hundred pounds of 10 10 10 in holes under it and after than I could grow grass. I drilled 1" holes and used a "oil change funnel" to put a big handfull of fertilizer in each one. Ruined the drill bit, it was one of the pig tail ones elelctricians use and in fact it was a worn out one someone gave me. I tried to resharpen it in my friend's Drill Doctor, but it ran away screaming.
Check with your county agent or local Extention Service agent. There may also be a Master Gardener program.
Jesper, Denmark
Jesper, Denmark
>You can use a potassium nitrate fertilizer, which the moss does not like. It helps some, but is not 100% effective. It may be difficult to get as it ia also used as an ingredient in explosives - like Oklahoma City bombing.
Ferrous sulfate is very effective in killing the moss and not the grass, but the moss goes an ugly black color before it disappears.
>Thank you all. I seem to remember hearing something about using Lime.
Now I have something to start with.
Many Thanks.
Mark
David Harker
>I love the look of moss in the shade, and would keep it.
Dave
