Cutting composite decking?
>I have a 12" compound miter saw (also a 10" tablesaw and a circular saw). What would be a reasonable blade to use to cut the composite decking material like Trex or Veranda?
Veranda decking - http://www.verandadeck.com/
Trex decking - http://www.trex.com/
I was figuring on getting the 2 blade pack of 12" carbide blades at the Borg which comes with a 32 tooth blade and an 80 tooth blade and using the 32 tooth blade.
The thought of not having to stain or paint a deck is somewhat appealing.
Re: Cutting composite decking?
>I just finished re-decking my dock with Choice Deck from Lowes at about $12/foot. It's easy to cut with a framing blade, and leaves a clean cricp edge. I did most of the cutting with a circular saw.
Clint
>Make'em carbide. The stuff wipes cheap blades. We used a "stock" blade in the chopsaw and a 40 tooth in the circ's.
mm
Jay St. Peter - Southern, MD
>I used both a 40 and 60 tooth blade in my 12" miter saw. I switched in the middle since I was cutting some vinyl railings. Both worked well. Just get cheap ones or use the one that came with the saw as they'll pretty much be beat when you're done. The stuff itself cuts like butter so you won't notice how dull your blade is until you try to cut something else with it.
On my saw I found that the dust catch bag was a negative thing. It clogged up and caused the stuff to pile up on the saw. It also clogged my Festool DC port and clogged up the works for the plunge mechanism. If you have (and plan to use) a Festool saw, use DC.
Jay
mdclor
>Depending where you live and which direction the deck faces, you might get a little mold or mildew on composite decking.
Good luck,
Merle
Bill Howatt
>I cut my Trex with a regular Delta 10" CMS. It also routs very nicely.
Bill
Ernie Miller
>If you check with a local saw mill areund here thay have 2X?? White Oak boards that are not dried that they sell for trailer decks that are planed on one side and ripped parrell in varing widths that are cheaper than buying SPF if you put it down why it is still green you can screw it down with out piolet holes it will Air dry on the deck and looks good when finished Last summer I think I paid about $.50 a bf and it will last forever will turn a silvery grey after a couple years. only caution is that if it is a second floor deck it will leave stains on any thing under it when it rains. All white Oak will do that dry or not
Post should have been up one thread?
Ernie Miller
Plan on tossing the blade
Lee Schierer - McKean, PA
>I installed a small deck 2 years ago with veranda. The blade on the skill saw had melted plastic on the sides by the time I was done. The shavings that get stuck to the blade by static eventually get hot and melt onto the blade.
Lee
Make that $2/ft
