Wood floor movement
Wood floor movement
Wood floor movement
Mike Baker
>Just a quick question!
I am just beggining an install of a red oak hardwood floor.
I need a good fit along a raised hearth and fireplace. I plan to scribe the fit on each board, then nail down as usual.
That fit is along the LENGTH plane of the floor.(Not width)
I plan to leave a 1/2 to 5/8 gap at the other end of the room! That distance is about 15 feet.
I have left about 3/4 of an inch on each side of the room. (Width dimension)
Will I be OK??
Thanks
Mike
Re: Wood floor movement
Re: Debunking the "flooring expansion" issue
Dave Mount, NE Minnesota
>You can fit the flooring tight on all sides of your hearth. The "gap for expansion" thing in wood strip flooring is an interesting convention. The fact is that wood floors don't (under normal circumstances) don't move as a unit -- the expansion is taken up at each individual joint, not at the edges. Think about it; if the floor expanded 3/4" at the edges during the summer (and the expansion would be way more than that if it was a 15' wide board), it would pull the nails at the edges and it would never go back the following winter. Also, you couldn't ever install a floor with a border, because the border would be pushed apart when the floor moved. A direct observation is that (unfortunately) I'm still missing a few pieces of baseboard in the house and the gap at the edge of the floor doesn't change dimension seasonally, it's the same today as it was when I laid it (OK, I don't have a caliper on it, but no perceptible movement). Another example is at the door thresholds where I laid the flooring to within 1/8" of the threshold and caulked the gap -- nothing has ever moved, the whole thing is stable.
Movement being taken up at the joints between individual boards is also why you don't glue the edges of solid wood flooring -- it would panelize the floor and it would start to move like one huge board.
So why does everyone say "leave a 1/2" for expansion"? Good question. Here's my belief of why it may be important. As I've explained, it is not needed under ordinary circumstances. But, it may be needed under extraordinary circumstances, i.e., catastrophic wetting of the floor. The power of expanding wood is incredible, and the amount a floor would expand if it were actually wetted to the fiber saturation point is way more than what would occur under normal seasonal cycles. Using figures from Hoadley's book, I calculate that a flatsawn red oak floor 15' wide would expand by over 12" going from 7% MC to 30% MC. An 80' wide hard maple floor (like gym or ballroom) would expand over 6 feet! I've seen pictures of things like gym floors that got flooded, and it's amazing to see the floor pulled up out of the subfloor and sitting there in "standing waves" as it curls in a sine wave to take up all the expanded width.
So how does this relate to flooring in a house? My thought is that a gap at the edge (and only along the long grain edge, obviously) is there so a catastrophically expanding floor doesn't push the walls out. Sounds crazy, but think about it. If there's a gap, then by the time the flooring edge reaches the sill plate, the nails holding it to the subfloor will be largely pulled from the subfloor (not completely maybe, but largely), which will allow the pressure from the expanding floor to be taken up vertically by buckling. If the floor were still firmly attached to the subfloor, the pressure would be applied more directly outward to the sill plate. The same would be generally true for glued floors -- the flooring to subfloor bond would have to be broken before the flooring reached the sill plates.
So getting back to your question, if you have a hearth in the mix, there's no need to leave a gap around it if it's in the middle of the floor (meaning that the front edge of it has the flooring strips butted into it), you can fit it tight on all sides. If it is at one side of the floor (i.e., you're laying flooring into it or away from it and the flooring is parallel to the front edge of the hearth), then you can still fit it tight, just leave the gap between the back of the hearth and the wall.
I'll caveat all this by saying that it is the only explanation I've ever come up with to explain something that is otherwise nonsensical. I've never had this theory affirmed by anyone with any authoritative knowledge; but then again, I've never had it countered by anyone with any authoritative knowledge. I actually wrote to Fine Homebuilding and presented this argument after they had an article on flooring that had the "1/2" for expansion" bit in it, but they didn't respond. As above I argued above, just the existence of floors with borders completely debunks the idea that the floor is moving perceptibly as a unit under normal circumstances. So if not that, why?
Another possible explanation is that gaps were originally left simply because there was no need to fit it tightly when it would be covered by baseboards and the expansion thing just grew up on its own. However, I hate to invoke an argument that the whole thing is a myth if there could be a rational explanation related to expansion.
If Andy Halterman (or anyone else in the flooring biz) is still hanging around, I'd be interested to hear his take on this. . .
Best,
Dave
Rod Peterson -- Ormond Beach
>I confess I haven't followed flooring discussions very much—just paid attention the times flooring was featured on the various DIY programs I've watched over the years. However, I suspect there may be some confusion between strip, nail down flooring, and the engineered, monolithic floors. Intuitively (with no empirical basis for argument), I would imagine that with strip flooring each piece of stock represents an individual universe in which a typical 2 or 2½" strip moves perhaps a 32nd at most, and since it's nailed (or glued), the movement is confined to that universe, not additive across the room. I also think it's fair to virtually ignore the movement along the length of the strip for a typical room.
The monoliths are a different story, however, in that each strip is joined to the next, and the universe is the whole—that is, movement is additive across the entire installation. The monoliths is where I've heard about leaving space around the perimeter. That said, I've often wondered, since so much of the engineered (whether true engineered with a real wood money layer or the laminate with a photo for the top layer) is a ply-like product with a composite substrate, why there would be any discernible movement at all.
In fact, when I helped my daughter and son-in-law with their engineered (Brazilian cherry finish layer) floor installation, we did it as a glue down (as recommended and endorsed by the manufacturer), and although they still recommended the gap on the perimeters, I have to say that after 24 hours that poly glue wasn't letting anything move anywhere, which begs the question as my suspicion above suggests, why leave the gap at all?
Yes, get Andy in here to set us right.
Rod
Jim Dillon
>Mike,
I'm no expert for sure, but I side with Dave and Ron on the need (or I should say non-need) for the expansion gap and really wish that Fine Homebuilding had gotten back to Dave on this question. I speculate that the need for the expansion gap arose many years ago when really wide plank floors were common, drying techniques were not widely available or used, fastening techniques were perhaps different, milling techniques (grooves on the bottom to allow air circulation) were not done, and the use of rosin paper to minimize moisture transfer - crawl spaces might have been a lot wetter then - was not available (though tar paper probably was).
Yet, having said all this, and having laid six rooms in our cabin with locust, heartwood pine, and vintage wormy oak (all 4-7 inch random width) I still went with the conventional expansion gap at the edges, because, gee, that's what is in all the books by "experts" 8-). Well, because I did my own baseboard, I could keep a eye on the places where the baseboard didn't quite cover the expansion gap (shabby work, I know 8-)), and in 7 years I've seen virtually (maybe a 1/32 inch or so)no movement from summer to winter in a NON-airconditioned cabin in the MD/VA region. So I hope someone with real experience sees this thread and can resolve the expansion gap issue; I, for one, am not convinced of its need.
Regarding your scribing to the stone fireplace, I suggest you consider beveling the cut just a bit so that you get a good tight fit to the stone (but don't be anal about it either). And I found the book by Don Bollinger on Hardwood Floors (Taunton Press) to be very helpful to a DIYer like myself (even though he uses the expansion gap in his examples). Go for it, laying flooring is fun!
Jim
Nice writeup Dave!
Jim Dillon
Indeed, great discussion
Bill Tindal, E.TN
>I aggree with Dave that there is nothing to be concerned about. Usually.
OTOH, I had a friend who built a large cabin that was basically one room downstairs with a sleeping loft upstairs. There were floor joists that over lapped on a center beam. The over lap was aobut four inches. The plywood subfloor "broke" or had a long joint that fell over the center beam. He laid homemade wide random wicth red oak flooring that he had been drying for years.
Turns out there was a spring under the cabin. The crawl space was constantly flooded. He laid the floor over a long weekend and shut the cabin up and left for the week. When he came back the floor had expanded and pushed the floor joists apart at the center and burst the cabin. The front door expanded on one end and the patio door on the other. It was so much wider that the floor joists actually fell off the beam on one side.
We had pleaded with him to deal with the spring, but he was going to do it later.
So, you don't have a wet crawl space do you?
Dave pretty well covered it.
Andy Halterman: We need more rain
>I'd only add that putting the ends or edges of a floor tight to a sill will generally end up causing a squeak or some kind of noise. That's the real reason we use tar paper under the wood. It only slows down moisture since you are penetrating it with nails. It's main purpose is so you don't have a wood on wood squeak develop.
You should have no problem going tight to the hearth. If you are slightly concerned, put a little liquid nails on the subfloor near the hearth for some extra holding power right there. Just a simple bead should do it.
With regards to the cabin story, I walked away from a job where there was standing water in the crawl space. The lady got someone else to put down 5" walnut prefinished floors. Wanna guess what happened when they went back to Florida for the winter?
Andy Halterman
A flooring "professional" who doesn't play one on TV in Hendersonville, NC�
One additional thought...
Jim Dillon
>... regarding the continued use of the "expansion" gap on the wall edge. As one gets closer to the wall, it becomes more difficult to really "seat" the flooring against the previously laid piece. For the final piece of flooring, the 1/2-3/4 inch gap allows one to use a prying-bar or large screwdriver to seat the flooring while it is nailed or screwed into place. Hence, the continued use of a gap might be more of a practical matter than for "expansion" per se.
Jim
Mike Baker
>Dave!!!!
Thanks SO Much for the time you took to give me things to think about!!:):):)
I too find it hard to believe that you MUST give the 1/2 to 3/4 clearance on the sides that the flooring companys suggest!! Your right,, if the floor moved that much seasonaly their would be alot of damage elsewhere!
Thanks again for your help!! The fit along the Fireplace and hearth is great,,And TIGHT:):)---- Scribing and coping is SOOO much fun!:)
Mike
Mike Baker
>NO WET CRAWL SPACE!!!!!:):) WOW!!!!
Re: Dave pretty well covered it.
Mike Baker
>Thank you Andy!!
I have laid the floor tight to the fireplace by scribing and coping each of the 3 1/4 inch boards. I also backcut the cope a bit, and the fit is great along the stone! I used a underlayment pad called "insulayment" that the flooring company suggested. Pricy, but nice. Its sposed to help with accoutics ,and keeping the floor closer to room temp! So, the floor is not laid down directly to the subfloor. I was anal about cutting the underlayment right to the edges!
Someone said earlier, that laying floor is fun!!!! I have found that I have sore muscles in places that I dint even knows yas had muscles!!! :):):)
Thanks again all!!
Mike
