Refinishing veneer
Refinishing veneer
Refinishing veneer
Lou Powell
>I am refinishing a 10 ft. walnut veneer conference table. The veneer has a few gouges but it is adhered well and in very good shape. There are some scratches that will require too much sanding to remove but I do want to remove the old varnish and apply 4 or 5 coats of oil & urethane topcoat. Is it OK to use Citristrip stripping gel to remove the old varnish on the table top. Will this affect the glue of the veneer?
Thanks for your help.
Lou
lgp@unh.edu
Re: Refinishing veneer
So far so good . . .
s.mackay@worldnet.att.net
>Been working a 30s sideboard the last couple weeks. The top, drawers and doors are all veneer. Useing 120 paper and will finnish later with 200 and its going at a good rate. The big caution I've heard was, just, NO MACHINES or power tools. I can see why. They'd go through this old stuff like buttuh ! To tell the truth I'm leary of putting stripper on it . . . I can, just, see it melt into a puddle on the floor. That, or leave it stained. I'm probably just faint of heart. Do a section or side every afternoon. Of course I make SWMBO " inspect " every day ! Gotta have my " OH-AH " fix !
>Hello Lou,
I've used stripper on veneer successfully. I removed it with 4/0 steel wool first, and then steel wool and water, and an immediate wipe up on a small area. After its dry, I hand sand with the grain very lightly with 320 grit and tack rag. Then stain. Small shallow scratches tend to disappear. Be stingey on the amount of water you use and the amount of time it lays on the wood. Alternatively, you can try Parks Furniture Refinisher according to directions on the can. Personally, I like it best. It can be done either way. I suggest you work outside and arrange to be left alone without interruption.
George
Paint removers don't harm veneer
Michael Dresdner
Yes it is ok, and no, paint removers do not harm veneer glue. If they did, the company making them would spend more time in court than formulating strippers since the vast majority of traditional and commercial furniture is veneered.
