ADVERTISE HERE - FREE TRIAL
OT - kinda - gauges of steel
Terry Alexander
>Ok...what is the difference in:
14 gauge steel
18 gauge steel
26 gauge steel
What would you use to cut each of these?
As always - thanks in advance!
Terry Alexander - wood scrap maker not a metal worker ;-)
Re: OT - kinda - gauges of steel
Pete LaBelle
>14 ga = 0.080"
18 ga = 0.047"
26 ga = 0.018" thick
Cutting equipment depends on whether cuts are straight, curved & how clean you want the cut. 26 ga can be cut with tin snips. Others will have to be cut with a saw, shear, nibbler or torch.
Re: OT - Now for the real question
Terry Alexander
>I have a Mueller building that is 26 ga. steel. I bought the Central Pneumatic Pistol Grip Air Shear from Harbor Freight just for this building. I buy HF tools when I need a tool for a one-time use. Anyway, it is advertised that this tool would cut through 14 ga. metal. Well.....we had to work hard hard hard to get it to cut through our 26 ga. steel lengthwise. It wouldn't even budge when we tried to cut across the "ripples" and bends in the metal.
Any suggestions? Technique?
My "assumption" is that if it is advertised to cut through 14 ga. it ought to smoke through 26 ga.
Any and all comments/suggestions would be appreciated.
Terry Alexander
Re: OT -And I have an additional ...
Jamie Donaldson
>... question for those in the know- are gauges in metal sheets and gauges in wire the same measuring standard for thickness?
Bill McDonald
>Sounds like a good excuse to get a plasma cutter :)
Re: Uh, yes...and no, sort of...
Al Stokka - Cambridge, Iowa
>Jamie,
One has to be specific as to material. For example let's use 14 gage. The decimal thickness for various metals are:
Steel, hot rolled: .0747
Steel, hot rolled pickled and oiled (P&O): .0747
Steel, cold rolled: .0747
Steel, galvanized - G90: .1084
Non-ferrous: .0641
Steel wire: .0800
Copper wire: .0641
It is always best to use decimal thickness rather than gage numbers.
Al
Re: OT - Now for the real question -Sawsall
Larry Clinton At Frankfort (Central)., Indiana
>A reciprocating saw will cut that metal easily, a saber saw with the right blade will also work - although not quite as fast. You also might try a metal (abrasive blade) in a circular saw. I have cut many feet with my sawsall and saber saw, have one of the circular blades - just never had an occasion to try it out. Another fairly quick method is using an Acetylene / oxygen cutting torch. This is overkill for 28 gage but will work. As to the Harbor freight shears - sometimes you get what you pay for :~>. I have a Kett electric shear - it will cut 28 gage with ease, but due to the jaw opening, not sure I could cut across the "waves".
>Tin snips will make short work of the lighter gauges.
And Larry is right. A Sawzall or Saber Saw will do it in a hurry too. Be sure to wear Eye protection. The chips are vicious.
