Bending Mahogany trim
Tom850i
>I need to bend a 20" piece of mahogany trim around a quarter circle that has an 11" radius. The trim is 1/2" thick and 2 1/4 " high. The style is door trim.
Can this be done without cutting kerfs on the back?
Re: Bending Mahogany trim
Joseph Mulherin
>Tom, I have heard many times about bending wood using Downy Fabric softener. You put the wood into a warm water bath with about a cup of Downy and it is supposed to soften the wood so it may be bent without using steam. Of course you could put the piece of wood into a steam tube and heat it with a burner so st4am softens the wood and then bend quickly before it cools. Go to WoodWeb.com and you should find out about the soft bending with fabric softener.
Steve Schoene
>Steam is the traditional bending agent. A plywood box, fed with a teakettle over a burner on high heat would soften the strip. That's a pretty gentle radius so it shouldn't be too tough. Of course you now have a reason to aquire more clamps if you don't have enough to clamp it very closely to the form.
Doubtful
>In my experience, mahogany is one of the worst bending woods. I've never had any luck bending it, with or without steam. I'd resaw it into thicknesses that will bend around your radius easily, and then laminate them to make up the thickness you need.
Ellis Walentine, Host
Agree. Recently did some.
Garrett in Victoria BC
>I recently completed a project using k.d. Honduras Mahogany, and needed to make some curves. No way would it bend without cracking. I glued up blocks and band-sawed them. Had they been larger, I wold have laminated thin strips in a form per Ellis's suggestion. (If you do this, make the form's curve just a little tighter to allow for spring-back.)
Cheers, Garrett
