tenon vise for table saw
Don Kruse
>looking for tenon vise that I can use on my table saw, must fir miter groove
Don Kruse
Re: tenon vise for table saw
Jim Hoeller
>I use one on a Sears table saw and replaced the original miter bar with a very straight piece of oak. The miter grove in the Sears is a few thousandths too narrow to accept the bar that came with the tenon jig.
Pete LaBelle
>Have used a JET and was happy with it. Recently purchased a Delta and it worked well too. Bought it thru Amazon for $69.
are you sure you need one
Bill Tindal, E.TN
>Let me preface by saying that maybe I never learned to use it to advantage, but, I purchased a high priced Delta tenon jig for my Delta saw many years ago. I never use it. The best way to make tenons that fit perfect is to saw them slightly over sized and then pare down to perfect fit with a shoulder plane. Neither I nor several of my woodworking friends ever came up with a mass production means of making a M&T joint that yielded perfect fits. (a perfect fit requires 0.005" tolerances.)
I saw the shoulders with a quality cross cut blade and waste out the rest of the tenon with a dado blade, leaving the tenon slightly over sized.
Re: tenon vise instead
>I have used a router table sled and a 1-1/4" planing bit for years. Easily adjustable to .002 or less if you need that kind of accuracy. I have 2 sleds; one fixed at 90* and the other variable to 60*. See Bill Hylton's "Router Magic" for the plans.
mm
Frank Klausz has a good one
>...and I coulda sworn we showcased it somewhere, either in American Woodworker or Woodworker's Journal, but I can't seem to lay my hands on it at the moment.
In essence, this jig resembles a tablesaw sled, except that it runs along a fence instead of having its own miter gauge rail. It has a cam-style workpiece clamp with multiple thickness ranges, depending on where you place the bolt.
If I find the plans I will post them, but I am not hopeful. Have a look at the concept and build your own. It is a winner.
