ADVERTISE HERE - FREE TRIAL
TV Cabinet for terrace
Tom850i
>I'm designing a TV cabinet for a 60" TV that will be outside on a covered terrace and need some help. While the TV will be sheltered from direct rain, it's possible some might blow in so I want to totally enclose the TV. I've considered pocket doors like you see on many entertainment centers, but they sometimes don't fit well and I would be concerned about them fitting well outside.
So, two questions; 1) what type of doors would you suggest and 2) what wood should I use? I thought about teak, but have never used it.
Thanks.
Re: TV Cabinet for terrace
Tricky design droblem
>A 60" wide screen means your doors will each be 30+" wide. Unless your cabinet is also 30"+ deep, it's going to be hard to get the doors out of the way, whether it's inside pockets or around the sides of the cabinet. Maybe one solution would be to make a single large door and hinge it at the top, so it folds back over the top of the cabinet. If the cabinet is shallow, you could make the door with two horizontal panels, hinged in the middle.
Regarding pocket doors, if you make them accurately and use good quality hardware, they should not be a problem. I've had better luck with the old style Accurides than with the newer versions that have European-style hinge cups. They seem to articulate too much, and on a door that is 30" wide, the weight could be an issue. There are much higher-end scissors-type pocket door hardware packages on the market, too, that would virtually guarantee a trouble-free job, but they are very pricey.
Speaking of scissors, why not consider houusing the TV in a low cabinet with a motorized scissors mechanism to raise it out of the base when in use?
Regarding your choice of wood, if you're going to finish this cabinet, you don't really need teak or another "outdoor" wood, but it wouldn't hurt. Regardless, you'll have to re-coat periodically -- usually once a year if exposed to the weather and two or three years if not.
Be sure you take into account the equilibrium moisture content of wood in your region. Unless you're in the Southwest, it will probably average out at about 12-14%. If you start with kiln-dried wood, it would be a good idea to let it acclimate outdoors for a while before you start making parts and pieces.
Hope this helps.
Ellis Walentine, Host
Robert Henderson
>How about a tambour door?
Tom850i
>The TV shell is 60" wide and 56" tall. I've never made a tambour door, and usually see them on small bread boxes. Can you make one that big?
Kneale Brownson in Northern MI
>Pretty large ones show up on rolltop desks.
Forget Teak. Too heavy & too expensive...........
Art Silva
>My choice would be Bald Cypress or Mahogany. The Cypress will never rot, and is strong enough for the job. It can be painted or stained. Mahogany costs more, but it machines as easily as Cypress and finishes well.
A Tambor roll-up is definitly out of the question. They are finicky enough in a dry situation, and should not be considered.
I think you should plan on a cover of some sort. Your worry is getting the TV to live outside, not the wood. Good luck. Art
Re: Forget Teak. Too heavy & too expensive........
Tom850i
>I'm thinking Mahogany is the best choice.
I've looked for large tambaur door hardware or doors and they have a maximum size much less than the size I need.
Maybe a baby size garage door......? If I could find a source.
Another choice might be regular hinged doors that can fold back 270 degrees so they are flat against the side of the cabinet when opened.
How about two tambors........
Ray Thompson - Middletown,IN
>that are vertical and open left and right.
Ray
Sure, you can do tambours
>I meant to suggest that as well. Just make the grooves for the tracks a little oversized, seal them well with epoxy and wax them for slick action.
Your other idea about the doors that wrp all the way around is also doable. Hafele used to sell hinges like this.
Re: How about two tambors........
Tom850i
>Good idea, but they would need to each be 56 + inches wide since that is the height of the TV box.
>Since it is under a cover, why not get some low glare non reflective glass and make a front and forget the doors?
Or you could do he Red Neck version and put a picture window in your house and put the TV indoors and watch form outdoors.
Design is a wonderful thing
>All you have to do to scale up to a tambour that tall is to use stock that is stiff enough. Tambours derive great strength from being glued to a common membrane with many others, so I don't forsee any great problems even if you made the tambours as thin as 1/2". You could err on the high side and make them 3/4" thick if you want. Be sure to use a glue that will stand up to humid conditions -- I'd probably use epoxy or even contact cement.
Tom850i
>I'll pass on the redneck idea....there's a stucco wall behind the unit.
I like the glass idea. The TV is on rollers, so I could roll it in and out from the side when needed. Or just make the glass frame so that it can be detached.
Re: TV Cabinet for terrace *LINK*
John Cotten
>Since you haven't mentioned the amount of space available, I would consider making a box with a fitted top and make the TV disappear vertically when not in use. While the motorized mechanizisms are expensive (around 1K or more), you can make one for around $150 to $200.
As far as the wood, I would consider lyptus or mahogany. Both will handle the weather but as Ellis mentioned, you will need to up grade the finish occassionally. I would use a good quality marine grade finish as used on a wooden boat.
lyptus. Great stuff to work with. The finish is pre-catalyized lacquer.
Lyptus and Curly Maple Vanity and Mirror
