>Hi Folks, I am in need of some advice . I am starting a blanket chest at my wife's request and am unsure of the thickness I should shoot for on the walls of the chest. I am using select pine from Lowe's (already thicknessed to 3/4). Should I leave it at 3/4 or would 2/4 be strong enough. I want it to last, but don't need to be picking up an awkward 50 lb. box whenever she gets the urge to rearrange the room (2-3 times a year). I appreciate any and all thoughts expressed.
>For pine, I'd leave it that thickness. Put some ball feet under it and you can pull it around with a blanket or throwrug turned upside down when rearrangement time reappears. If it's a carpeted room, use an old shower curtain.
>Traditional blanket chests are 7/8 to 1 inch thick. I made many pine blanket chests that were 15/16" and they were light enough for one person to lift and carry etc. I think in your case the weight of the contents will be just as much a factor as the weight of the chest. I think 3/4 is the bare minimum for the chest to have reasonable strength.
The one which I built for my wife is of aromatic red cedar, and I milled it to 3/4", and used box joints for structure . Its plenty strong. I used 7/8" curly maple for the top.
