ADVERTISE HERE - FREE TRIAL
Atlas Lathe Question
Dick Krieger
>I own one of the common TH42 Atlas Metal lathes. I often turn wood on it so I guess it qualifies as a wood question !!! My question is: How do I tighten up the two cross feed knobs on the compound tool rest. Both the crossfeed and the tool rest knobs turn so easily, that they often move when using lathe. Do I assume there is a half-nut somewhere that needs to be adjusted or what?? I know some of you probably have this tool or something like it. There is not an excessive amount of backlash between turning in or out, but the handles just move so easily.
Any help would be greatly appreciated.
Dick Krieger
Re: Atlas Lathe Question
Gibs
John in New Mexico
>there are gib screws on the right hand side of the adjustable crossfeed, not sure about the fixed crossfeed. If there's minimal backlash, tighten up the gib screws and lubricate the gibs and that should tighten it up. As far as I remember, there's no halfnuts on the crossfeeds, only on the long feed.
John
