Last Step in Finishing Cabinets
Howard
>I spray a lot of lacquer and I generally stop at the last coat without any further rubout, relying on how the final coat lays out from the gun. On a few occassions I've gotten a bit more orange peel than I'd like and I would like to know the real practical way to get that hand rubbed smooth feel. What do the production cabinet shops do to get that feel, I can't believe that they actually take rubbing compounds or abranet, etc. to every nook and cranny in every door they produce. Most production doors have a very nice feel to them. What's their "secret". Thanks for reading.
Re: Last Step in Finishing Cabinets
Steve Schoene
>The higher end production shops do some rubbing out. That's a principal reason they are high end shops.
They probably also have the ability to make fine adjustments to the thinner and other spray characteristics to minimize defects. The environmental conditions--temperature and humidity--are also probably closely controlled. And, it probably doesn't hurt that the guys with the gun in hand are spraying some 200+ days a year.
Ed Mulligan, Cape Cod
>In my experience thin coats are the path to a finish off the gun. In the cabinet shop where I used to work virtually all spray work was done with nitrocellulose lacquer and there was no rub-out step. The luster used there was approximately a semi-gloss. Most work got 1 coat of sanding sealer followed by hand sanding and then two coats of lacquer.
For high-volume makers, I don't know but I suspect they are using some sort of robot spray system and perhaps special spray products that require careful attention to temperature etc. I recently toured a high end guitar factory; both the spraying and rub-out (for gloss finishes) were done by robots.
Ed
Howard
>Thanks guys, this is sort of what I thought about the bigger shops. It does become challenging at times controlling temp,etc. in my spray booth.
What kind of lacquer are you using?
John Cotten
>I use pre-catalyzed lacquer beceause in my old shop it was hard to control temprature and humidity. I don't know yet how difficult it will be in my new shop. One big difference is most high end shops use conversion varnish instead of lacquer. This is actually a vinyl finish. This is a difficult finish to work with, but yields the best results. You have to play chemist when mixing the hardner with the finish, and measurements are critical, but the results are worth it.
The other thing is surface prep before you spray. Make sure all of the microdust is off the piece. Tack cloth between coats, make sure to not spray too many coats. Too much can be worse than not enough. 3 coats is the standard in my shop, although on some surfaces 2 work just fine. At 4 or more you are going to start getting some buildup that is not desirable.
One other thing, nitrocellulose lacquer may require a permit in some areas to spray. The EPA really cracked down on it a few years ago, and started enforcing permitting here in KY. Some finishing suppilers I work with don't even offer it now.
